The Shelly4hass custom integration and the native shelly integration use the same domain “shelly”. This is the reason why you cannot use both at the same time.
But it is possible to move Shelly4hass to a new domain.
shut down homeassistant
in the custom_components/shelly directory change const.py
DOMAIN = ‘shelly’ → DOMAIN = ‘shelly4h’
in the custom_components/shelly directory change manifest.json
“domain”: “shelly” → “domain”: “shelly4h”,
“name”: “Shelly” → “name”: “Shelly4hass”
in config_flow.py:
return self.async_create_entry(
title=“Shelly4hass”,
data=system_options
and
async def async_step_final(self):
data=self._options
in .homeassistant/.storage/core.config_entries:
and
“title”: “Shelly4hass”,
in .homeassistant/.storage/core.device_registry:
“identifiers”: [[“shelly4h”,…]]
in .homeassistant/.storage/core.entity_registry:
“platform”:“shelly4”
in configuration.yaml:
shelly: → shelly4h: (if you have that)
ShellyForHass will no longer receive further development updates. This decision stems from the fact that its features and functionality have been seamlessly integrated into Home Assistant, making it redundant to maintain a separate plugin.
It is not possible to use the core integration while you have Shelly4hass still active. This means you have to migrate somehow from Shelly4hass to Shelly native.
Do you think the native Shelly integration takes over the 50 old S4H entities?
And if not, how do I know what “shelly_shem_3_d8bfc01a7fae_1_current_consumption” is that is used in 4 automations and 3 template sensors?
Correct I never had the need for Shell4hass. Right from when I started using Shelly devices five years ago, back then mqtt and the HA restful integration was all that was needed for full functionality but as the core Shelly integration got better I switched over to that.
