ShellyBLE with Inkbird IBS-TH2
I am looking for some guidance on what may be causing an issue I am encountering. I have multiple Shelly PlugUS that my fridge/freezers are plugged into. Then I have the Inkbird temp sensors in these frezzers to monitor temps. It has all worked fine until a few days ago. The setup is the Shelly plugs are connected using the shelly integration. When I turn on active or passive bluetooth it then automatically finds the Inkbird sensors and adds them under the inkbird integration. Like I said a few days ago it worked, but now the inkbirds say there are no devices or entities. I have tried many different things to try to fix this, removing and readding everything, firmware updates, etc. No luck.
I turned on Debug Logging on the bluetooth integration and I do see the updates from the shelly into HA. An example of the inkbird data is below cut from the logs. I assume this is temp data but no entities are found. Any suggestions on other things to try? Thanks!
<BluetoothServiceInfoBleak name=tps address=49:24:03:04:06:F2 rssi=-66 manufacturer_data={63306: b’\x00\x00\x00\x8f\xba\x19\x06’, 63296: b’\x00\x00\x00\x17\xbb\x1b\x06’, 63286: b’\x00\x00\x00\xdep\x1b\x06’, 63316: b"\x00\x00\x00’\xb8\x1a\x06", 63326: b’\x00\x00\x00\xbf\xb9\x1a\x06’, 63336: b’\x00\x00\x00w\xbd\x1a\x06’, 63346: b’\x00\x00\x00.\x7f\x1a\x06’, 63356: b’\x00\x00\x00G\xbe\x1a\x06’, 63366: b’\x00\x00\x00\x9f\xaa\x1a\x06’, 63376: b’\x00\x00\x00\xd6i\x1a\x06’, 63386: b’\x00\x00\x00Nh\x1a\x06’, 63396: b’\x00\x00\x00g\xad\x1b\x06’, 63406: b’\x00\x00\x00\xff\xac\x1a\x06’, 63416: b’\x00\x00\x00\xb6o\x1a\x06’, 63426: b’\x00\x00\x00o\xa5\x1a\x06’, 63436: b’\x00\x00\x00\x06d\x19\x06’, 63446: b’\x00\x00\x00_\xa6\x1a\x06’, 63456: b’\x00\x00\x00\x97\xa2\x1a\x06’, 63466: b’\x00\x00\x00\x0f\xa3\x1a\x06’, 63476: b’\x00\x00\x00\xa7\xa1\x1a\x06’, 63486: b’\x00\x00\x00?\xa0\x1a\x06’, 63496: b’\x00\x00\x00\xf4\xa1\x1a\x06’} service_data={} service_uuids=[‘0000fff0-0000-1000-8000-00805f9b34fb’] source=C8:2E:18:12:7D:8A connectable=False time=377832.346052475 tx_power=None raw=b’\x02\x01\x06\x03\x02\xf0\xff\x04\ttps\n\xffJ\xf7\x00\x00\x00\x8f\xba\x19\x06’> match: set()
Well for anyone wondering I did manage to fix this. It looks like something broke with 2025.5.1 but the owner of the inkbird code already submitted a pull request with a fix. I made a custom component to overwrite the inkbird integration with his fix and it works and my devices and entities appear again. I assume the next update will include the fix so the custom thing isn’t necessary. :slight_smile:
