Way to drag up an old post, but…
I’ve tested MotionEye on and off for a while on an RPi and an Intel NUC with a J5005 CPU, but with a Synology NAS as my primary CCTV capture device - it just works so well. I’ve also tried Zoneminder in the past, I found it very difficult to get to work in docker, so never stuck with it. (I would love an AIO docker solution if anyone has one)
I wanted to ditch the NAS, an old DS115j and move to a single solution for HA, CCTV, and Plex for my media content, so decided to have a play around with an old Dell SFF Optiplex 990 running Ubuntu server 18.04.03 LTS, with a i5 2400, 8gb RAM and a 2TB WD Purple Drive I pulled out of the NAS.
I installed MotionEye using Docker, and got everything set up. CPU usage was sitting constantly in the region of 60%-70% usage with 4 cameras on continuous record. I find the motion detection in MotionEye to be unreliable and it drops frames constantly - 1 second I’m in the video, next second, gone. Power usage was constantly sitting at 80 watts, which in Australia becomes expensive for an always-on system. I know this a somewhat due to old CPU architecture. File sizes using Foscam FI9853EP’s were in the region of 800mb per 10min video on medium/high capture settings.
I stumbled across Shinobi, and decided to give it a go.
Installed using docker and it’s running very well. I’m very impressed with it so far. The learning curve for setup is much higher than MotionEye, but once I got the hang of it, I found it easy to configure.
CPU usage is around 5% and RAM usage is around 15% (of 8gb) and power usage is sitting at 30-35 watts - much less taxing on the system than MotionEye. Files sizes for a 15min video on roughly the same quality settings as MotionEye are around 240mb, significantly smaller for 50% longer record time.
Being that Frenck is no longer developing the community container for this, I have just added it to HA via an iframe.
I came searching on the forums for info about Shinobi as I couldn’t believe I hadn’t heard of it before, and found this thread, so thought I would share my experience with it so far. Perhaps the development of the software has improved and it is something that more HA should look into using.
