Shopping_list items not adding after upgrade to 0.107.7
Hello All,
I have recently updated to v0.107.7 and now my shopping_list is not working.
# DEFAULT CONFIGURATION FOR HASSIO
default_config:
# SHOPPING LIST
shopping_list:
My old shopping list has disappeared and when i try to add a new item nothing happens (e.g. not added to the list).
Any ideas?
I get the following in log
Received invalid command: shopping_list/items
Received invalid command: shopping_list/items/add
I had the same problem
https://github.com/home-assistant/core/issues/32176 helped
I turned off problem automation and everything works
Thanks i cleared all congif restarted and then re-added. now solved thanks.
For all those searching for an answer and finding this thread. As noted in the post below, after updating you seem to need to configure it in the frontend (Integrations > Configuration > Discovered).
