Shopping list
Hi, I can use shopping list component in italian language.
I modified the intents in shopping.py. The original EN file was:
hass.components.conversation.async_register(INTENT_ADD_ITEM, [
    'Add {item} to my shopping list',
hass.components.conversation.async_register(INTENT_LAST_ITEMS, [
    'What is on my shopping list'
In IT language:
    'Aggiungi {item} alla lista della spesa',
    'Mostra lista della spesa'
In configuration.yaml you need only to add:
shopping_list:
Surely non the neatest solution but it works :slight_smile:
I am having the same problem on 0.57.2
Hi, I am italian too, can you tell me a bit more step by step, what I need to do, to have it in Italian.
In configuration?
conversation:
  intents:
    ShoppingListAddItem:
      - Add {item} to my shopping list
shopping_list:
Hi Claudio,
I created a custom component cloned from the original shopping.py and placed it under my custom_components folder.
I modified the intents in my custom shopping.py from:
‘Add {item} to my shopping list’,
‘What is on my shopping list’
to:
‘Mostra lista della spesa’
In configuration.yaml you don’t need to add specific intents, so you configuration.yaml should look like:
conversation:
shopping_list:
Hope this helps
Ste
You can also do this without creating a custom component. This is what I have in my configuration.yaml to enable shopping-list commands for the Dutch language
The required intents are defined in shopping_list.py, so that’s where those come from.
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
  intents:
    HassShoppingListAddItem:
      - Zet {item} op de boodschappenlijst
    HassShoppingListLastItems:
      - Wat staat er op de boodschappenlijst
i gave it a try again and apparently it works now. I’m on HA version 0.61.1.
However, I tried to change the sentence to…
intents:
    - Add {item} into shopping list
or add more variations such as…
intents:
    - Add {item} into my shopping list
    - Add {item} to shopping list
…none of them works. My configuration doesn’t take effect. Only Add {item} to my shopping list works.
What happen when you say “Wat staat er op de boodschappenlijst”? Does it show you the items in your shopping list? Can you share a screenshot of how it looks like?
I am trying to create an automation for my Telegram bot where I ask “What is in my shopping list?” and it will reply back with the list of items in my shopping list.
Here’s a screenshot. It shows the top 5 items on my shopping list. In reality, there were actually eight items. In reality, I don’t really use this function, as i’d rather just look at the list itself (and check of the items as I go through the supermarket).
Same here :frowning:
