Hi everyone, I would like to add a button in the dashboard that opens the Entities tab in Settings > Devices & Services > Entities.
Does anyone know if this is possible?
Thanks!
R.
Thanks!
R.
Absolutely!
I’m not at my PC right now so can’t post the yaml, but look at panel_custom
edit: Here you go…
- name: ha_entities
sidebar_title: Entities
sidebar_icon: mdi:cog-outline
js_url: /api/hassio/app/entrypoint.js
url_path: 'config/entities'
embed_iframe: true
#require_admin: true
config:
ingress: core_configurator
working perfectly for me on HA 2024.1.3
…are you accessing HA though https or http?
i_frame does not work over https (I think).
OK, well just deleting the post makes me look like a madman chatting to myself.
I guess I need some help how to configure this end to end then?
Add the code to configuration.yaml, and then how to get it to show on dashboard?
Sorry, I was going to avoid being a noob and research more myself before noticing a response. Thanks.
no worries being a noob, we were all that once and sometimes you don’t even know where to start
did you check this link I posted above?
The full script for you configuration is:
panel_custom:
- name: ha_entities
embed_iframe: true
config:
and then restart HA.
