When I try to update any of the Update Available nodes, I get something like this:
INFO Reading configuration /config/esphome/everything-presence-one-d53110.yaml...
INFO Updating https://github.com/everythingsmarthome/presence-one.git@main
WARNING GPIO15 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
Failed config
binary_sensor.gpio: [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:108]
platform: gpio
pin:
number: 33
mode: INPUT_PULLDOWN
device_class: motion
filters: [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:116]
- [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:116]
This option is not templatable!.
delayed_off: !lambda |-
return id(pir_off_latency).state * 1000.0; [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:116]
binary_sensor.template: [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:117]
platform: template
device_class: occupancy
filters: [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:122]
- [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:122]
return id(occupancy_off_latency).state * 1000.0; [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:122]
on_state:
- lambda: id(illuminance_sensor).update();
lambda: |-
if ( id(mmwave).state or id(pir_motion_sensor).state) {
return true;
else if (id(mmwave).state == 0 and id(pir_motion_sensor).state == 0) {
return false;
else {
return id(occupancy).state;
switch.template: [source /config/esphome/.esphome/packages/0c0347a4/common/everything-presence-one-base.yaml:137]
platform: template
disabled_by_default: True
entity_category: config
optimistic: True
[import_full_config] is an invalid option for [dashboard_import]. Please check the indentation.
Am I broken?
