I am using a SONOFF Universal Zigbee 3.0 USB Dongle Plus Gateway with Antenna and a SONOFF SNZB-04 Door/windows sensor.
My front door is on the other side of a wall maybe 5 meters away, probably less. the walls are fairly standard thikness, think the house as build in the first half of the 19th century (a terrace in the UK).
When I first got it I set it up and put in in a plastic storage box (a few meters from the Gateway so it was not opening or closing). After a while (1 or 2 days I think) it went unavailable. I am fairly sure I got it out and placed the 2 pices together and it became available again.
I then put it on the front door. I set up a Node-RED flow to t owarn me if door was left open for more than 2 minutes. I tested it and it semed to work. I then left it and forgot about it.
In the early houres of the morining I got woken up my the alert I had set up. I looked and it was unacailable. It was last activated 6 houres ago. Obviously this is far from ideal :). I opened /closed the door and it was available again.
I did some reading up and it may be I got a duff (people who have seceral they find most do not go unavailable but some do, whitch they get replaced) but others seem to think this is a vcmon problem.
What are peoples experience with rgese sensors. I’ve heard good things about the Aqara ones (i.e. 5 years battery like) but gather that they are not zigbee 3. They are zigbe, just not zigbee 3. Will Aqara ones work well with my SONOFF Gateway? Should I switch?
I heard good thinks about the Lidl ones but they are not in my local store.
