Should my base_url be my Nabu Casa remote URL or my local IP?
Suppose I primarily access my HA instance with the Nabu Casa remote UI url (e.g. https://abcdef1234.ui.nabu.casa/ ). Should my configuration.yaml have the base_url set to my local IP (e.g. http://192.168.1.100 ) or my Nabu Casa URL?
Neither. base_url is deprecated and replaced by internal and external url settings.
Except for Google TTS where base_url is now required to get it working. But this glitch will hopefully be fixed.
Thanks for the info. I’m literally trying to setup Google TTS for the first time. Should the base_url be the internal URL then?
The external url. And I mean that you should add the base_url to the tts: part of configuration.yaml. It should not be under http:. So like this:
tts:
  - platform: google_translate
    service_name: google_say
    language: nl
    base_url: <your external url>
