Should rpm be a unit of speed?
I have several MQTT fan sensors which are configured with the following discovery topic.
  "name": "Element 0 Actual speed",
  "unique_id": "md1200_mqtt_element_0_actual_speed",
  "state_topic": "isilentllc/sensor/md1200_mqtt_element_0/state",
  "unit_of_measurement": "rpm",
  "device_class": "speed",
  "value_template": "{{ value_json.speed }}"
This results in a warning in the logbook that rpm is not a valid unit for device class speed.
Should rpm be a unit of speed or should this sensor have another class?
I lean towards adding rpm to the allowed speed units, but thought maybe there was a reason that it was excluded and that there was another preferred option for the device class.
According to the manual Sensor - Home Assistant there is no device class for it.
You could make a feature request for adding rotation_speed as a new device class
by definition “speed” is displacement of position over time (miles per hour, meters per second, etc). RPM doesn’t measure that parameter so using speed as a device class wouldn’t make any sense. RPM is a measure of angular displacement over time or angular velocity.
people colloquially use speed for rpm but that’s not technically correct.
While this is technically correct, the best kind of correct for certain, I’m not convinced that adding a new device class with angular velocity units makes sense. I’ve yet to see a fan controller labeled with anything other than speed. And as much as I’m a fan, pun intended, of being correct, I have to admit, I’d label it in the ui as speed also.
People colloquially use velocity for speed but that’s not technically correct either.
People colloquially use mass for weight but that’s not technically correct either.
Physicists are such pedants.
Well, this topic starts to get some rpm’s :smiley:
Can we please have radians/sec.
Out of curiosity, what device type do you have in mind that would use radians/sec?
An SI fan :slight_smile:
Hah, I wondered if that was the case. Makes sense, just hadn’t seen a fan with those units.
Why not? we have device classes being requested for other “strange” measurements. There’s an entire FR thread devoted to them.
those would be the units.
the device class would still be angular velocity.
:wink: :laughing:
Yeah I know :slight_smile:
haha, I found this thread again… always looking for RPM solution. I just realized that this message (along with other rpm-related messages) keep showing up in my logs:
Entity sensor.deckard_fan_2_speed (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using native unit of measurement 'RPM' which is not a valid unit for the device class ('speed') it is using; expected one of ['in/h', 'm/s', 'Beaufort', 'mm/h', 'mm/d', 'km/h', 'ft/s', 'kn', 'mph', 'in/d']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
Did you guys notice that we have support for Beaufort scale?? I’ve never heard of that so I had to look it up: Beaufort scale - Wikipedia apparently for wind speed and its relationship to land or sea based on empirical data! That’s more important than reporting accurate scales for nickrout’s SI fan?!
I think if we can support a Beaufort scale as a speed, we can support RPM as a speed! Who’s with me??
There’s not really any big benefit for using a specific device class other than being able to convert between units in the UI and you also get a default icon. Adding RPM to the speed device class would break the unit conversion feature and you’d be left with the sole benefit of getting a different default icon…. yay :man_shrugging:
The main issue in this thread seems to be the error messages resulting from using RPM with the speed device class. And this is easily solved by not specifying a device_class, or specifying None.
To summarize: An RPM sensor should have unit_of_measurement: RPM and also state_class: measurement and you’ll get zero errors and it will function and appear as you’d expect.
If there’s going to be a change to add the RPM unit, it would need to go into a new device class or else use the existing device class frequency. It’s not an option to lump it into a device class like speed due to the unit selection/conversion functionality.
This makes sense to me. Thanks Rick!
This is so funny ! I have set up a variable speed pool pump that I can now control the speed of it. I looked for rpm and found none. I couldn’t find anything that fit, and it complained about RPM.
I literally stumbled across the Beaufort unit, and I kind of think it’s for storm wind velocity. I thought the same thing. If there are beauforts, there’s gotta be rpm. I literally set my pump units to Beauforts, and it doesn’t seem to matter at all, but the errors went away. I figured that the chance of confusing any other units with Beauforts was about zero.
Crazy coincidence.
Found this thread today for the very same reason.
Perhaps the closest class in terms of physical quantity being measured could be frequency, 60 RPM being 1 RPS = 1 Hz. Adding RPM unit here would seem weird, although not technically wrong in you think of it as rotations per unit of time.
For slower rotational speeds, or if you think of it as rotation per unit of time, then angular velocity would be more appropriate. This reminds me that HA does not have neither acceleration nor angular velocity units, while accelerometer and gyroscope sensors are quite common.
RPM and even RPS unit could be added to both classes, to emphasize what is being measured.
