There seems to be a user permission issue…
I have Google-assistant as a user without admin rights dedicated to Google Assistant.
I’ve wrote the a script exposed to Google assistant using “Activate kitchen dashboard” phrase to run this script. The script is confirmed working via UI using my owner admin account.
But when calling it through Google Assistant, I get the following error:
2021-03-31 10:56:45 INFO (MainThread) [homeassistant.components.script.cast_kitchen_display_action] cast_kitchen_display_action: Executing step call service
2021-03-31 10:56:45 ERROR (MainThread) [homeassistant.components.script.cast_kitchen_display_action] cast_kitchen_display_action: Error executing script. Unauthorized for call_service at pos 1: Unauthorized
2021-03-31 10:56:45 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1041, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 254, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 262, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 463, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1488, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1523, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 708, in admin_handler
raise Unauthorized(context=call.context)
homeassistant.exceptions.Unauthorized: Unauthorized
However, setting Google-assistant user account to be Administrator does not give the error and works perfectly.
Purpose of this thread
- Should Cast be an admin-only function?
- What level of permission should we give to voice assistants?
- Any concern in enabling admin for Google assistant?
My answer to first 2 are: No, cast should be available to all users. All users should always have lowest possible permission setting.
