Plug a monitor into home assistant and I’m see these errors
Screen slowly fulling up
They are not errors.
They are logs of cron jobs. Perfectly normal.
There is a way to suppress these logs, let me see if I can find it…
Thanks bro sum more reading.
Here is the topic I was thinking of:
So mine were command line logs (which I no longer use).
Not sure how to suppress whatever is making your logs.
Do you have a utility meter with a cron pattern for the reset cycle?
