I have this code to get info about the trim level of my motor from NMEA2000 into the ESP that controls trim and jackplate, by sending it on MQTT from Node-RED:
I need it to be current or not there at all. If the ignition is turned off, the engine interface does not receive changes in the trim, and then I can’t use that as the basis for an automation. The problem is that it doesn’t obey the “expire_after”. if I send a value over MQTT it will stay there until the ESP reboots. Does anybody know why it isn’t obeying the expire?
Ah ok.
Well that expire_after is specifically for HA itself. The “trimsensor” value, if exported to HA, should expire in HA after 10s (marked unknown)
I understand your’re doing node-red->ESP, so it’s irrelevant for your use case.
You actually want the pure MQTT publish expiry I mention above, I think.
Really? I thought this would work internally in the ESP, so I could use it in an automation there. Hass does not come into this equation for me in this case. Here’s what’s written under that sensor:
The mqtt_subscribe sensor platform allows you to get external data into ESPHome. The sensor will subscribe to messages on the given MQTT topic and parse each message into a floating point number.
And this is about expiring in the general sensor setup:
MQTT Options:
expire_after (Optional, Time): Manually set the time in which the sensor values should be marked as “expired”/“unknown”. Not providing any value means no expiry.
Wrong sensor. That’s the regular MQTT Sensor, not the MQTT_subscribe sensor. That is here:
And the expire is not a part of that sensor, it is a part of the base sensor configuration and should be valid for everything that are defined as a sensor.
Damn, those guys from ESPhome on Github are fast! And you are right, it’s the outgoing message that expires in 10 seconds in my code. But they also had the solution for me:
