Hi there,
is it possible to show an alternative text to ‘home’ / ‘not home’ for devices detected by device tracker. If I check the devices are on, showing ‘on’ / ‘off’ would be better.
Thanks for your help, Tom
Hi there,
What device tracker integration are you using?
I’m using nmap.
You could create a binary sensor for each one. That’s about all I can think of.
That’s exactly I was looking for. Thanks a lot!
FWIW, that’s pretty much what I meant above, although I should have said a Template Binary Sensor to be more specific. Then you can even set a device_class
if there’s one that is appropriate for your use case.
