Show camera snapshot when alarm to HA app
Hi, may i know how can i push the snapshot into HA app notification whenever my home alarm is triggered? I have multiple Xiaomi Dafang and Foscam camera.
Thanks in advance.
Sorry I’m not home so i won’t be able to format this use
service camera.snapshot
entity_id: camera.mycamera
filename: www/snapshots/mypic.jpg
then send it with
service notify.mobile_app
image: ‘https://mywebaddress/local/snapshots/deck.jpg
message: This is my picture
Lots of good info on how to do this here: https://companion.home-assistant.io/docs/notifications/notification-attachments
That’s a nice information, serves my need. Now, i just need to figure out where will my camera store the image.
You define that in the camera.snapshot service call: Camera - Home Assistant
I can’t seem to be able to get images to show up in notifications, doesn’t matter what I try.
This is my code (using nabu casa):
      - service: camera.snapshot
          entity_id: camera.hikvision_cam
          filename: '/config/www/images/frontdoor.jpg'
      - service: notify.mobile_app_sm_j530y
          message: "Motion detected at door {{now().strftime('%H:%M %d-%m-%Y')}}"
            image: "https://someid.ui.nabu.casa/local/config/www/images/frontdoor.jpg"
Any ideas? It works fine with other external (non-nabu casa) links…
            image: "https://someid.ui.nabu.casa/local/images/frontdoor.jpg"
the www folder in your config directory is just local so no need for the extra part
I think you can use relative paths, so you can also use:
image: "/local/images/frontdoor.jpg"
This avoids it loading the image from the external URL when you are on the local WiFi.
you can, I was just pointing out what was wrong with the URL :slight_smile: its also documented on the site that I linked to up above
Awesome - thank you. I know it’s something simple but after a few thousand lines of yaml over a couple of years it’s something I never picked up…
Can you send multiple images in the same notification? i.e. I have 8 cameras and would like to send all 8 snapshots when the alarm goes off but I am only able to send one at a time.
only 1 at a time
Thought that might the case, thanks
