Dear all,
I configured various light bulbs and motion sensors with zha. I defined some automations to turn on and off the bulbs. So far everything is fine.
The lights may be also turned on using light switches. If this is the case the status in home assistant will not be updated, they still are shown as “off”.
Is there a way to catch the correct status of a bulb when the status has not been set via home assistant?
Thanks for your help!
