Show device tracker Attributes
I am using google map device tracker, and i want to create a card with device tracker and device tracker Attributes in same card, such as:
  • State
  • Battery level
  • Battery charging
This is the entity:
1- How to add the Attributes parameters ?
2- Which card to use ? (lovelace)
3- I try to create a sensor using this code: but i get error:
  • platform: template
    sensors:
    phone_battery:
    friendly_name: ‘Phone Battery’
    value_template: ‘{{states.device_tracker.google_maps_000000000000000000000.attributes.battery_level | round}}’
    unit_of_measurement: ‘%’
Hi Danik,
What error do you get?
This is the sensor.yaml
this is the error:
Your problem might be in the formatting of your template sensor, I can’t really tell if the formatting is correct by looking at that picture but it should look like this:
  sensors:
    phone_battery:
      friendly_name: Phone Battery
      value_template: '{{states.device_tracker.google_maps_000000000000000000000.attributes.battery_level | round}}'
      unit_of_measurement: '%'
Give that a try.
Still get error:
The issue with the error was solved, tnx to @Jardiamj for the help!
the solution:
The block right under “- platform: template” wasn’t indented, the whole block needed to be moved 2 spaces to the right
