Show image depending on input_text
I try to get the status of a device represented by an image. What is the best way to do this?
I was thinking about making conditional badges (10+) and just show the state (string). But there might be better solutions.
Btw. the badges don’t seem to work with states (it just shows always):
    badges:
      - entity: sensor.test
        state_filter: "Unbekannt"
        image: /local/badges/problem.png
You cannot use the frontend state display, but the backend state term unknown. Check the proper spelling under Developer Tools > Services.
Some people use template sensors for this to get a whole bunch of it in one.
Sorry that wasn’t clear. This is a template sensor showing exactly this and other states. There must be another mistake.
Ah, ok. But I’ve overlooked the type. Correctly it’s
type: entity-filter
    badges:
      type: entity-filter
Where do I put the type?
When you compare once more with the documentation examples, you’ll see that it has to be
    badges:
      - type: entity-filter
        entities:
          - entity: …
            image: /local/…
            state_filter:
              - 'Unbekannt'
        show_empty: false
Thanks a lot.
Wild cards or are probably not supported, right?
Also, is it possible to use actions on tap?
