I got the notify to work, so when a sensor is tripped HA takes a photo and send it to HA ios App.
I can see the notification on the lock screen, and a small small picture. When i try to open the notification i get nothing.
I’d like to see notification history as well with the option to dismiss notifications after you are done with them. If anyone has a Ubiquiti Unifi Controller, the functionality could be similar to the alerts window.
If your phone supports 3D touch, just use that to use the attachment. Otherwise, swipe left on the notification and you should see an option to view that will allow you to see the image.
