I hope someone can point me in the right direction for a card I would like to add to my dashboard.
I have a Shelly device that is connected to my irrigation system (which has a separate rain sensor) which I would like to know when it last ran.
The sensor is that the irrigation is on is called sensor.shelly_2_5_fgeleftgpu_power_0
When the irrigation runs it generally draws about 7W but I have noticed that from time to time there is a draw of around 2W when the irrigation is not running.
Therefore I would like to create a card that I display on my dashboard that is a date and time of when this sensor exceeded 3W so I know when the plants were last watered.
Thats the idea but I have to say im a bit lost where to start with creating that and I hope someone might point me to an example or documentation I might use? I have searched tna.
So I’m thinking you could easily accomplish this by creating a Date/Time Helper that you update with an automation when your trigger/conditions are met. You can add a Date/Time helper to an Area so it will show up on the automatic Overview or you can add this helper as a card if you have a custom dashboard. Based on your question this had my interest piqued as I’d like to know when the last time my pool pump has run. I’m going to give this a try myself.
I chose this because I’m more interested to know the last time it turned off verses when it turned on because I have a visible timer that tells me how much runtime is left.
Thats awesome thanks for setting me on the right track. I added the helper as a card to the dashboard and created the following automation which I hope will do the job:
alias: Update Help When Irrigations Starts
description: ''
- type: power
platform: device
device_id: 03931a57c9da7e4d488f20ce4b5aef2a
entity_id: sensor.shelly_2_5_fgeleftgpu_power_0
domain: sensor
above: 4
condition: []
- service: input_datetime.set_datetime
datetime: '{{ now().strftime(''%Y-%m-%d %H:%M:%S'') }}'
entity_id: input_datetime.irrigation_helper
mode: single
