Show light brightness value instead of on/off toggle
I’ve got some lights that I want to see the brightness level in number form instead of the on/off toggle. Is there a way to show that?
Have you tried the light card?
I can’t try it at the min, but looks like it should do what you want?
Not quite what I was looking for. Just need a simple display of the light brightness in integer form, no icons or control features.
You could create a template sensor from the light brightness attribute and use that in a glance or entities card.
I literally just did this and tested it out when your reply came in… And it works! Thanks.
I know you said you don’t want control but thought I’d show you this just in case:
Yeah, That’s not for this circumstance. However that looks very cool and I will definitely be converting some other controls over to that.
BTW, This project was for replacing the light brightness level with a temperature readout. I’ve got several Nest thermostat accounts to monitor and HA only allows one to be setup. I wrote some code in Nodered to monitor all my accounts and pass the temps into HA.
