Show only part of icon -- wipe/slide icon
Hi all,
I think I might be stretching the limits of this particular forum, but I thought I’d respectfully ask all the same.
I’m trying to show that something is working by showing a wipe or slide (not sure how to describe it) animation.
Something like below.
Please be kind if this question is outside the confines of this forum.
Thank you.
Ben
Interesting idea, do you want
  • animated icon: why not create a gif?
  • a changing icon: then you could use some logic to change form 1 icon to the next in a rotating manner with (say) 5 icons
  • change the icon while sliding it: I have no clue what could be possible
Thanks for the suggestion, I didn’t know that GIF can be an icon.
Ideally, what I’d like is to use some sort of animation on an icon because I’m using custom:button-card and its templating abilities. This way I can reuse this animation.
Consider using animation for the icon, kind of
          @keyframes shift {
            0% {
              transform: translateX(100%);
            100% {
              transform: translateX(-100%);
and the icon must be inside a square container with overflow=hidden.
Thanks for the suggestion.
I added this inside the extra_styles section of the custom:button-card
The card is close to square it is 75x85, I could change it, but I"m not sure where to put the overflow=hidden. This is not a parameter I’ve seen before.
Right now, the animation goes from right to left right to left, but it doesn’t seem like it is “swiping”. But as I said I don’t have the overflow=hidden on, because I don’t know where to put it.
