Show state of a switch
I’m trying the create a Entity Card, that shows the state of a switch without the option to change the state. I don’t want anyone turning the washer off while it’s working.
Something like the last line:
  - entity: switch.shelly_xxxx
    icon: mdi:power
    state_color: true
    secondary_info: last-changed
    toggle:false
I’m not aware of a display option to remove it, but you could create a template sensor that displays the state:
The template sensor is a good idea, the other option is to lock the switch with the Lovelace restriction card.
you can also just add a confirmation to the box
tap_action:
  action: toggle
  confirmation: true
It’ll pop up a confirmation box everytime you want to turn on or off the switch
