Is it possible to change the elapsed time from an “about” to a precise time? So if the change was 1 hour and 18 Minutes ago, the tile doesn’t say 1 hour? It is really nerving for the cards I use, as they should show me the elapsed time of running programmes.
Current code of the tile
type: conditional
conditions:
- condition: state
entity: binary_sensor.waschmaschine_lauft
state: 'on'
card:
type: tile
vertical: true
color: blue
state_content:
- last-changed
- sensor_value
tap_action:
action: none
icon: mdi:washing-machine
Hey i hadnt forgotten about this I just have family staying over Christmas period so all my advice has been using my phone and from memory of mushroom card CSS. But i dont remember this stuff for the tile card so took a bit longer to figure out
Below code will hide the normal secondary line and replace it with whatever you write in the content: '';
bit.
type: conditional
conditions:
- condition: state
state: 'on'
card:
type: tile
vertical: true
color: blue
state_content:
- last-changed
- sensor_value
tap_action:
action: none
card_mod:
style:
ha-tile-info$: |
.secondary {
color: transparent !important;
.secondary:before {
content: 'Test';
display: flex;
justify-content: center;
color: var(--secondary-text-color);
Then you need a piece of code that figures out the time between last changes and now. This is my favourite version it isnt short, but its the most accurate i have found:
{%- set time = (as_timestamp(now()) - as_timestamp(states.binary_sensor.waschmaschine_lauft.last_changed)) | int %}
{%- set minutes = ((time % 3600) // 60) %}
{%- set minutes = '{}m'.format(minutes) if minutes > 0 else '' %}
{%- set hours = ((time % 86400) // 3600) %}
{%- set hours = '{}h '.format(hours) if hours > 0 else '' %}
{%- set days = (time // 86400) %}
{%- set days = '{}d '.format(days) if days > 0 else '' %}
{{ 'Less than 1 min' if time < 60 else days + hours + minutes }}
Combined with your card:
type: conditional
conditions:
- condition: state
state: 'on'
card:
type: tile
vertical: true
color: blue
state_content:
- last-changed
- sensor_value
tap_action:
action: none
card_mod:
style:
ha-tile-info$: |
.secondary {
.secondary:before {
content: '{%- set time = (as_timestamp(now()) - as_timestamp(states.binary_sensor.waschmaschine_lauft.last_changed)) | int %} {%- set minutes = ((time % 3600) // 60) %} {%- set minutes = '{}m'.format(minutes) if minutes > 0 else '' %} {%- set hours = ((time % 86400) // 3600) %} {%- set hours = '{}h '.format(hours) if hours > 0 else '' %} {%- set days = (time // 86400) %} {%- set days = '{}d '.format(days) if days > 0 else '' %} {{ 'Less than 1 min' if time < 60 else days + hours + minutes }}';
display: flex;
color: var(--secondary-text-color) !important;
Of course translate whatever you need into German
Thank you! This helps us really much to follow up on possible overloads etc of our appliances.
Have a wonderful weekend and “guten Rutsch” into the new year!
