Hi
I have a video streaming device, that I can view content using the following type,URL visible via VLC.
http://192.168.1.123:8888/video.ts
How best can I make this stream visible on the HASS dashboard
Hi
Do you know what format the video stream is?
If you can’t find your modele/device in the camera components, you can try some of the generic integrations like Generic IP Camera or Generic MJPEG IP Camera
It says that the encoded video format is AVC, which I assume is the following.
It looks like I might have the ability to have 4 seperate streams (each with their own IP). Other streaming options include Unicast and multicast. Currently I just have it set to http.
then you should be able to use Generic MJPEG IP Camera
