Showing geo tracking on maps
Hi all,
Hopefully this isn’t a duplicate of an existing issue.
I have the Android companion app and it is sending geo data to my home assistant instance.
My map card settings are as follows:
type: map
entities:
  - entity: sensor.hillmob_geocoded_location
  - entity: zone.home
  - entity: device_tracker.hillmob
default_zoom: 15
hours_to_show: 48
dark_mode: false
Tracking is not appearing on the map. What could I be doing wrong?
Roland
  1. What is your map card like, then?
  2. What are the attributes under sensor.hillmob_geocoded_location and under device_tracker.hillmob
I’m guessing the sensor.hillmob_geocoded_location is not map-ready, since it does not have GPS coordination (latitude/longitude) in its attributes.
is your device tracker updating its state properly? if not check these steps: Troubleshooting | Home Assistant Companion Docs
Thanks @k8gg and @dshokouhi
I did check and recheck the trouble shooting page before I posted (not that I said that :slight_smile: )
The crash logs have these lines, but since I haven’t been away from that location I’m not sure if it’s being updated. I assume they are as the history I shared (image) shows multiple locations.
03-07 15:50:49.639 23246 23246 D LocBroadcastReceiver: Last Location:
03-07 15:50:49.639 23246 23246 D LocBroadcastReceiver: Coords:(-37.6981012, 176.286271)
03-07 15:50:49.639 23246 23246 D LocBroadcastReceiver: Accuracy: 20.0
03-07 15:50:49.639 23246 23246 D LocBroadcastReceiver: Bearing: 0.0
03-07 15:50:49.641 23246 23246 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
03-07 15:50:49.641 23246 23246 D LocBroadcastReceiver: Received location that is 53 milliseconds old, 1646621449588 compared to 1646621449641 with source fused
03-07 15:50:49.641 23246 23246 D LocBroadcastReceiver: Duplicate location received, not sending to HA
The sensor.hillmob_geocoded_location displays data as follows:
Administrative Area: Bay of Plenty
Country: New Zealand
ISO Country Code: NZ
Latitude: -37.698116
Locality: Papamoa
Longitude: 176.28621
Postal Code: '3118'
Sub Administrative Area: 'null'
Sub Locality: Papamoa Beach
Sub Thoroughfare: '564'
Thoroughfare: Papamoa Beach Road
icon: mdi:map
friendly_name: hillmob Geocoded Location
Oh…just saw this post Lovelace map card not displaying geocoded entities - #10 by petro, is that the solution? Not sure why I can’t use the sensor as is…
Any other thoughts?
Roland
The latest beta version of the Android app fixes this issue and the sensor should work as expected in the map card
Many thanks @dshokouhi. I’m on the beta version…and there is an update available so will go and test!
[UPDATE: Issue is resolved. Thank you @dshokouhi]
