Sht3xd ( or other i2x sensors) api Does not provide internal access to temperature or humidity (protected)
Hello folks, my first post !
so i am trying to display the temperature of sht3xd on my esphome device. the current workaround is to let the device publish to HA server and then retrieve the temp entity from HA server toward the esphome device and display it on the OLED … but it would make much sense to expose the two sensors inside sht3xd class as the are now private declared …
here is my Yaml and the error message associated any clue ?
  - platform: rotary_encoder
    restore_mode : RESTORE_DEFAULT_ZERO
    publish_initial_value : true
    resolution : 2
    pin_a: 2
    pin_b: 15
    min_value: 0
    max_value: 100
  - platform: sht3xd
    temperature:
    humidity:
    address: 0x44
    update_interval: 60s
  - platform: adc
    pin: 39
    unit_of_measurement: "lux"
    update_interval: 30s
    raw: true
    attenuation: 11dB
    accuracy_decimals: 1
  - platform: homeassistant
    entity_id: sensor.bedroomsensor_temperature
    internal: true
    entity_id: sensor.bedroomsensor_humidity
    internal: true
time:
display:
  - platform: ssd1306_i2c
    flip_y : false
    flip_x : false
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      // Print "Mitt Smarta Hus" in top center.
      it.printf(64, 0, id(arialfont_x_small_), TextAlign::TOP_CENTER, "bedroom Sensor");
      if (id(rotary).state >= 0)
        it.printf(0, 0, id(arialfont_x_small_), TextAlign::TOP_LEFT, "%.0f" , id(rotary).state);
      // Print time in HH:MM format
      it.strftime(5, 40, id(arialfont), TextAlign::BASELINE_LEFT, "%H:%M", id(esptime).now());
      it.printf(127, 23, id(arialfont_small), TextAlign::TOP_RIGHT , "%.1f°",id(tempSensor).temperature_sensor_->state);
      //if (id(this_temp).has_state()) {
      //  it.printf(127, 23, id(arialfont_small), TextAlign::TOP_RIGHT , "%.1f°", id(this_temp).state);
      // Print outside temperature (from homeassistant sensor)
      if (id(this_hum).has_state()) {
        it.printf(127, 60, id(arialfont_small), TextAlign::BASELINE_RIGHT , "%.1f%%", id(this_hum).state);
error as described :
/config/esphome/bedroomsensor.yaml: In lambda function:
/config/esphome/bedroomsensor.yaml:150:87: error: 'esphome::sensor::Sensor* esphome::sht3xd::SHT3XDComponent::temperature_sensor_' is protected within this context
You placed id: tempsensor on the wrong line. Change it like this:
  - platform: sht3xd
    temperature:
    humidity:
    address: 0x44
Then the next line in the display lambda will work:
it.printf(127, 23, id(arialfont_small), TextAlign::TOP_RIGHT , "%.1f°",id(tempSensor).state);
