Shuffle todo entries
Is there any way to regularly shuffle todo entries? For example once a day. Or manually with a script. I didn’t find any solution via YAML. I went for a python script, but ended at the situation that this python script didn’t find any todo entries.
# python_scripts/shuffle_todo_list.py
def main():
    try:
        todo_list = hass.states.get("todo.mylist")
        if not todo_list:
            raise ValueError("❌ Entität 'todo.mylist' existiert nicht")
        items = todo_list.attributes.get("items") or todo_list.attributes.get("tasks") or []
        logger.debug(f"Debug: Gefundene Attribute -> {todo_list.attributes.keys()}")
        logger.info(f"Anzahl aller Einträge: {len(items)}")
        if not items:  # Check if the list is empty
            logger.warning("ℹ️ Keine Einträge in der To-Do-Liste")
            return
        active_items = []
        for idx, item in enumerate(items, 1):
            if not isinstance(item, dict):
                logger.error(f"⚠️ Ungültiger Eintrag (Index {idx}): {item}")
                continue
            status = item.get("status", "needs_action").lower().strip()
            if status in ["needs_action", "active"]:
                active_items.append((
                    item.get("uid", f"missing_uid_{idx}"),
                    item.get("summary", f"Unbenannter Eintrag {idx}")
        if not active_items:
            logger.warning("ℹ️ Keine aktiven Einträge (Status: 'needs_action' oder 'active')")
            return
        shuffled = sorted(
            active_items,
            key=lambda x: hash(f"{x[0]}_{int(hass.time.timestamp())}")
        removed_uids = []
        try:
            for uid, summary in active_items:
                hass.services.call(
                    "todo",
                    "remove_item",
                    {"entity_id": "todo.mylist", "item": uid},
                    blocking=True
                removed_uids.append(uid)
            for _, summary in shuffled:
                hass.services.call(
                    "todo",
                    "add_item",
                    {"entity_id": "todo.mylist", "item": summary},
                    blocking=True
            logger.info(f"✅ Erfolgreich {len(active_items)} Einträge gemischt")
        except Exception as e:
            logger.error(f"🔥 Kritischer Fehler: {str(e)}")
            logger.info("🔄 Versuche Rollback...")
            for uid in removed_uids:
                try:  # Add a try-except block for the rollback
                    hass.services.call(
                        "todo",
                        "add_item",
                        {"entity_id": "todo.mylist", "item": next(s for u, s in active_items if u == uid)},
                        blocking=True
                except Exception as rollback_e:
                    logger.error(f"🔥 Rollback Fehler für UID {uid}: {rollback_e}")
            raise  # Re-raise the original exception after rollback attempt
        logger.error(f"💥 Schwerwiegender Fehler: {str(e)}")
        raise
main()
Any easier way to get this to work?
