Shutdown does not work
I am running HA in virtualbox on a windows 11 computer. Every time I try to shutdown HA properly via ‘send shutdown signal’ the system hangs.
So I use ‘shutdown machine’, but that simply cuts off all activities.
What can I do to clear this malfunctioning?
Running HA in virtualbox on a windows 11 computer.
  • Core 2024.11.0
  • Supervisor 2024.11.4
  • Operating System 14.0
  • Frontend 20241106.0
Hi brinkgit,
Home Assistant Command line command list is here:
But that’s not what you are looking at. You are looking at whatever Linux is running in that virtual terminal in windows. I don’t have any idea what you need there. Look at the documentation for the virtual kmachine software you picked.
Use the shutdown tools inside of HA and don’t mess with this is my suggestion.
Using the shutdown tool inside HA results also in an hanging system. Reboot is also than the only optiopn.
Problem solved. something was wrong in virtualbox. After re-install virtualbox things worked normal again.
