Hello Community,
i use a template for the defintion of a shutter (cover)
platform: template
covers:
logo1shutter1:
device_class: shutter
friendly_name: "Logo1Shutter1 (Kids Area)"
#position_template: "{{ 100 - (states('sensor.LogoShutter1Position') | int) }}"
position_template: "{{ states('sensor.Logo1Shutter1Position') | int }}"
# Action to open the shutter
open_cover:
- action: cover.open_cover
entity_id: cover.Logo1Shutter1Cover
# Action to close the shutter
close_cover:
- action: cover.close_cover
# Action to stop the shutter
stop_cover:
- action: switch.turn_on
entity_id: switch.LogoKidsAreaShutter1AppStop
- delay: "00:00:01" # Wait for 1 second
- action: switch.turn_off
# Action to set shutter position (drag and drop)
set_cover_position:
- action: modbus.write_register
hub: SiemensLogo1
address: 153 # Modbus Adress
#value: "{{100 - (position) }}" # Write the target position (0-100 scale) to register
value: "{{position}}" # Write the target position (0-100 scale) to register
this entity is used by the customShutterCard
which supports
can_tilt
in my case it is not possible to add these two parameters
unitl i add one, i get this error:
open_cover_tilt
close_cover_tilt
all i want is to change the value of the position from the shutter whennthe Button for tilt up or down ist pressed
how can this be solved?
Many thanks for any help
Daniel
