Tsar
(Christian)
January 20, 2022, 5:10pm
1
I want my shutters down at sunset (+offset), for wich I created a sensor, but at last at a certain time (helper).
So I created this automatisation
alias: Rolluiken 's avonds neer
description: ''
- platform: time
at: sensor.rolluik_avond
- platform: time
at: input_datetime.tijdstip_rolluik_avond
condition:
- condition: template
value_template: '{{ now() <= today_at(states(''input_datetime.tijdstip_rolluik_avond'')) }}'
value_template: '{{ now() <= states(''sensor.rolluik_avond'') | as_datetime }}'
- service: script.rolluiken_automatisch_neer
mode: single
I presume it’s a problem of miliseconds, but don’t know how to fix it…
Hellis81
(Hellis81)
January 20, 2022, 9:48pm
2
Unless the sensor and helper has the exact same time then it will only trigger at the later of the two since both is in the condition like that (assuming the <=
should actually be >=
firstof9
(firstof9)
January 20, 2022, 9:50pm
3
why not use the condition:
- condition: sun
before: sunset
before_offset: "1:00:00"
Hellis81
(Hellis81)
January 20, 2022, 9:52pm
4
I believe that is the sensors value if I understood it correctly.
I’m not sure I understand the conditions at all.
The way I see it the have no use.
Do they?
It’s time triggered, so what’s the condition for?
firstof9
(firstof9)
January 20, 2022, 9:59pm
5
Sorry, I meant the trigger:
- platform: sun
event: sunset
offset: "-01:00:00"
Tsar
(Christian)
January 21, 2022, 7:03am
6
This is my sensor :
- name: 'Rolluik avond'
unique_id: 'sensor_rolluik_avond'
state: >
{{ state_attr('sun.sun', 'next_setting') | as_datetime + timedelta(minutes = states('input_number.offset_rolluik_avond')|int(0)) }}
device_class: timestamp
Changed a little (add 1 minute), so I hope it will go down this evening…
description: ''
- platform: time
- platform: time
condition:
value_template: >-
{{ now() <= today_at(states('input_datetime.tijdstip_rolluik_avond')) +
timedelta(minutes=1) }}
value_template: >-
{{ now() <= states('sensor.rolluik_avond') | as_datetime +
mode: single
So I suppose shutters will go down at 17:24:59
In summer, when sunset is at f.e. 22:40 the shutters should go down at 22:00
Hellis81
(Hellis81)
January 21, 2022, 7:07am
7
I still don’t see a reason for the conditions.
What is the difference between:
description: ''
- platform: time
- platform: time
condition:
value_template: >-
value_template: >-
mode: single
and this:
description: ''
- platform: time
- platform: time
condition: []
mode: single
Both will trigger at both times, and both will close the shutters at whatever time is the first.
So what is the condition for?
Tsar
(Christian)
January 21, 2022, 8:12am
8
True, but with the conditions it will only occurs on time (at: sensor.rolluik_avond OR at: input_datetime.tijdstip_rolluik_avond) not twice…correct ?
Hellis81
(Hellis81)
January 21, 2022, 8:16am
9
Conditions are AND not OR.
So both conditions has to be true in order for the automation to trigger.
Since Now() has to be less than your variable then it could be that your trigger wont happen because you made it complicated for no reason.
Say Now is 20:00, sensor is 17:00 and input_datetime is 22:00.
That means the sensor is less than Now thus condition will fail.
What is the reason for the conditions? What are they supposed to do?
Tsar
(Christian)
January 21, 2022, 8:23am
10
In your example the shutters are already down at 17:00 (is less than 17:01 and les than 22:01).
I want my shutters down at sensor time but at last at input_datetime (22:00).
Hellis81
(Hellis81)
January 21, 2022, 8:27am
11
Not if HA is restarted at 16:59. This makes the 17:00 fail, and the 22:00 fail because Now() is larger than sensor.
Yes… I know… But explain the purpose of the conditions.
Unless the example above they will always evaluate to true
so you might as well replace the conditions with {{ true }}
because it’s the same thing.
Tsar
(Christian)
January 21, 2022, 8:31am
12
If I do not place these conditions, the trigger will hit twice…and I would like to avoid that.
Tsar
(Christian)
January 21, 2022, 8:44am
13
Why ?
If my sensor is 17:00 and my input_datetime 22:00, then my shutters go down at 17:00 (both conditions are true).
But at 22:00 the first condition is false (not less than 17:01)
Hellis81
(Hellis81)
January 21, 2022, 8:55am
14
That is true.
But I would rather have an input boolean that is set to true when down, then reset the boolean at midnight or if an automation is used to roll them up again.
Tsar
(Christian)
January 21, 2022, 9:03am
15
Yes, that’s true. I will think about it.
Thanks !
Tsar
(Christian)
February 15, 2022, 7:21am
16
@Hellis81
Just fyi and to confirm that the solution without a boolean works fine, so I took the same solution for the shutters to go up.
Worked fine, until today…the reason is that both triggers went off on within a time span of a some seconds
So I will add this, so the automatisation runs only once (I took 12 hours between) :
value_template: >-
{{ ( as_timestamp(now()) -
as_timestamp(state_attr('automation.1642230056582',
'last_triggered')) |int(0) ) > 43200 }}
Is there another way to do this (I found this solution in another topic), cause now I have to search that ID… ?
