I spent a lot of time to get it, but it went me crazy, I couldn’t found any good advices.
I have:
- Sensors at Doors / Windows to check if they are open
- Rollershutters
- Free@Home integration
In manually everything is working well.
I do want to achieve the following:
- driving shutters down at sun.sunset with offset +/- [a slider at gui]-minutes + x-minutes random (set by a slider and enabled by true/false-switch in GUI [off means no extra+offset, on means random minutes offset)
- if door is open, than shutter’s position stop at 50%, exit from driving, till door is closed
- if door is closed, first step, drive shutters to 50%
- if shutters is at e.g. 60%, than do not drive to 50%, stay at this position (60%) without moving
- wait for x-minutes (set by a slider and enabled by true/false-switch in GUI) + x-minutes random (set by slider and enabled by true/false-switch in GUI)
- drive to 100% down
- have a button in gui to enable/disable whole automation for this specific shutter
In other programming languages I would get it to go, but in YAML I am a totaly noob.
Please advice me to more about learning YAML to achieve my goal.
This is my “code” so far:
alias: "Shutter door down 2 steps"
description: ""
- platform: time
at: "23:10:00"
- platform: sun
event: sunset
offset: 0
condition: []
# get current_position, for check if > 50%
# tried to have a number-helper-entity, but do not know ho to set state / value to
# delay for waiting to execute step 1
- delay: "{{ (range(0, 2)|random|int) | multiply(60) }}"
# step 1
- device_id: 1e8bb6503abc322a8771c70a8e4f4144
domain: cover
entity_id: cover.shutter_door
type: set_position
position: 50
# wait for step 2 (for testing in seconds
- delay: "{{ range(2, 5)|random|int }}"
# step 2
domain: cover
type: set_position
position: 100
mode: single
Regards
