SI7021 Sonoff sensor wired to esp32
Hey All,
First attempt at using esp32 home. I’ve purchased these boards; Amazon.co.uk. (i think i have the board type correct)
flashed them and now up and going over OTA, i’m trying to wire up the Si7021 sensor. It has three wires, white, red and black. I have the White connected to 02, red to 3v3 and black to GND. flashed it with the below config;
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
#  board: nodemcu-32s
wifi:
  ssid: "Home"
  password: "<removed>"
  ap:
    ssid: "Kitchen Fallback Hotspot"
    password: "X3e69v28lq2z"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  - platform: dht
    pin: 2
    temperature:
      name: "Living Room Temperature"
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
and is complaining about this;
[21:45:57][W][dht:154]: Waiting for DHT communication to clear failed!
[21:45:57][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[21:45:57][D][sensor:092]: ‘Living Room Temperature’: Sending state nan °C with 1 decimals of accuracy
[21:45:57][D][sensor:092]: ‘Living Room Humidity’: Sending state nan % with 0 decimals of accuracy
anyone have any thoughts?
Maybe try the htu21d platform.
That info comes from a note about the SI7021 sensor on this page.
Hope its of help.
Thanks, will try this configuration.
I have confired i2c, i’m not to sure which pins to connect the wires to now: i have the three from my sensor, 3v3, GND and Data.
Which one does the data connect to as i2c has two , 21 and 22?
This page should help.
And the data and clock pins should be marked on the SI7021, or it’s data sheet.
However this tells me its not a SI7021.
Thanks, this is what I purchased
SONOFF Si7021 Sensor Temperature and Humidity Sensor for SONOFF TH10 and SONOFF TH16 Smart WiFi Switch,(–40℃~85°C, 0~100% RH) High Accuracy Monitor Temperature Humidity Sensor https://www.amazon.co.uk/dp/B075LN2SQ2/ref=cm_sw_r_cp_api_i_AiaeFbVA0B893
It’s not i2c. I have a couple I use with a Sonoff S22 and works great. Perhaps check the Tasmota Template to see how it should be connected and configured.
That look to have 4 ring connector on the plug in the Amazon photo. :thinking:
edit: this might help as it has relevant info.
  - platform: dht
    pin: 2
    temperature:
    humidity:
You need to specify the model:
model ( Optional , int): Manually specify the DHT model, can be one of AUTO_DETECT , DHT11 , DHT22 , AM2302 , RHT03 , SI7021 and helps with some connection issues. Defaults to AUTO_DETECT . Auto detection doesn’t work for the SI7021 chip.
Support has been dropped after recent ESPhome update. Go back to tasmota as the sensor is a rigged 2 wire protocol, not i2c
Hello! I would like to raise this issue again. Since I am now faced with a support problem (the result is the same as in the original post) but with Sonoff THR316 (ESP32) and as I understand, nothing has changed yet, there is still no support?
I was able to wire one of the Sonoff SI7021 up to a Sonoff Basic using this configuration, working fine with ESPHome 2024.11.
  - platform: dht
    model: si7021
    pin: GPIO14
    temperature:
      name: ${friendly_name} Temperature
    humidity:
On the hardware end of things, I cut the audio jack connector off and striped the wire. Then, I learned about a type of wire I hadn’t really seen before, litz wire, or enameled wire. With this the inner wires are not in their own jacket, they just have a coating on them to prevent them touching each other. All you have to do is hit it with a lighter for a second to burn off the enamel. Probably best to check for continuity before soldering/adding connectors to it.
