hello,
I am trying to use SIA integration with Bentel Absoluta, since the absoluta use the UDP I need to run SIA integration on UDP, but it fails (on TCP it works)
2023-09-01 18:08:51.322 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SIA Alarm on port 3061' for sia integration not ready yet: SIA Server at port 3061 could not start.; Retrying in background
There is no other process/integration that is running already on that port, I can’t get any additional info to debug the error.
Someone has the same issue?
thanks
