Sidebar entry deleted
Hello, I have deleted the map entry some time ago in my sidebar and now I can’t enable it again. I don’t disabled it over there menu of long press on the sidebar header. Is there another way to enable it again?
Greets
Christian
Click your icon in the lower left
edit here
I know this, but I can’t add the entry. It is not showing. When I delete here another entry, I can enable it again. I thing, I have disabled my entry in a configuration file.
Sorry that wasn’t clear from your post so I am starting from ground zero…
Is default_config: in your configuration.yaml?
I’m not seeing too many similar issues posted…
another possible solution, add a map dashboard then add to sidebar.
Settings>dashboard>add dashboard> map>add to sidebar
Thank you, this is the solution.
