Siemens EQ 9 / Home Connect Alt / select.xyz to custom switch?
Hello everyone,
I hope I’m in the right forum.
I integrated my Siemens EQ.9 via the “Home Connect Alt” integration. So far everything works.
However, I don’t see a switch for turning the coffee machine on and off.
There is only the following entity:
select.siemens_ti9575x1de_68a40e256c81_bsh_common_setting_powerstate
with the following attributes:
  • options: BSH.Common.EnumType.PowerState.On, BSH.Common.EnumType.PowerState.Standby
  • device_class: home_connect_alt__settings
  • icon: mdi:tune
  • friendly_name: Siemens coffee machine - Power State
Now how can I build a switch that toggles between the PowerState.On and PowerState.Standby options? The individual symbol should be visible either dark (standby) or yellow (on).
Can someone help me there?
Many thanks in advance.
Greetings
