Siemens Webserver ozw672
My heatpump is a Fujitsu and uses the Siemens OEM controler. I also have an Siemens Websterver attached to it, so it can be controled in the following ways:
  1. directly (webinterface on the server exposed to the Internet),
  2. through a mobile app (for iOS & Android - really old looking) or
  3. via the https://www.climatixic.com/ website
or even as a KNX device
The documentation states, that the webserver also responds to web API calls. And someone at https://forum.fhem.de/index.php?topic=32866.0 already made a script and even a module for that platform. The way I understand there are bunch of JSON calls involved.
My development skills are rather limited, but I would like to connect the heatpump to my HA setup.
I’m willing to provide my server as a test enviroment. Is there someone willing to help me out or at least point me into the right direction?
Hi, i have the same request.
Webserver OZW672 with climaticix.com for Brƶtje BGB 38E
Do you have some solution with Home Assistant?
Thank you
it seems that someone already tried to use OZW672 API in https://github.com/NextDom/plugin-ozw672/blob/e4d1fdfeb0b76372b3a95f9da593bac60af342cb/doc/fr_FR/api.asciidoc. Its in french, but the examples seems usable.
I am planning to incorporate it into Home Assistant somehow, but no eta.
For example, my Baxi boiler with LMS15 regulator has Boiler temp with datapoint id 1323:
curl -sk ā€˜https://10.0.0.193/api/menutree/datapoint_desc.json?SessionId=&Id=1323’|jq .Description.Value
ā€œ30.765625ā€
I saw this solution too, but i am only "end user " and this is too hard for me. From Siemens i have full description for API Interface (and how connect it for web ā€œwww.siemens-syncoic.comā€ or ā€œclimatixIC.comā€ via API), For me, it would be enough to use only the existing cloud from Siemens, but control and see it in HA. This API Interface in PDF has (85 sites). If are there some better Programmers via Addons Home Assistent, I’m very happy to provide this PDF Api Document some Developer. :blush:
@venca.kratky
I dont have time for proper integration (or maybe much later), but it shouldnt take much time to prepare some widgets for reading temperature and setting some basic stuff via the REST API. Depends on what exactly you expect to measure/control over Home Assistant. Just to set temp, control on/off for heating is ok, setting the proper equitherm curve over HA would be bit harder. Brƶtje BGB 38E seems to be using same Siemens regulator LMS15 as my Baxi boiler, so the datapoints should be ± same, probably depending on the accessory (DWH, sensors, …). I dont think I need 85 PDF for that, when I can just list all items via the API and just pick what I need :slight_smile:
Hi @venca.kratky. I would like to give it a shot with using the REST Sensor component. Would you be so kind and share the pdf with me? Also what is the version of OWZ firmware that your document refers to?
Hi Tilen, thank you for reply. I send PDF per Message. About OZW, i have Firmware OZW672.1 on Build 07.00.21.52. In this moment, i am connecting to Cloud on https://www.siemens-syncoic.com, but in HA it would be better :slight_smile:
Hi Venco !
here is my solution using REST platform :
- platform: rest
  resource: http://192.168.x.x/api/auth/login.json?user=xxx&pwd=xxx
  value_template: '{{ value_json.SessionId }}'
  scan_interval: 3600
- platform: rest
  resource_template: http://192.168.x.x/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=8833
  name: HotJet venkovnĆ­ teplota
  value_template: '{{ value_json.Data.Value | float }}'
  unit_of_measurement: "°C"
  device_class: temperature
Hoping it will help.
P.S.: May I ask you to send me OZW API Description, please ?
Hi @wewerk,
thanks for this. Exactly what I needed to continue. You have the pdf in a personal message.
Best
Thank you, Hoping it will help.
I finally got around implementing this. Worked as expected. My code:
  - platform: rest
    resource: http://192.168.1.3/api/auth/login.json?user=XXXX&pwd=XXXXX
    scan_interval: 86400
  - platform: rest
    name: Fujitsu Outside Temperature
    resource_template: http://192.168.1.3/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=1065
  - platform: rest
    name: Fujitsu HC1 Status
    resource_template: http://192.168.1.3/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=448
    value_template: '{{ value_json.Data.Value }}'
Hi all, after few Months i had time for little playing with OZW672 webserver and my Brƶtje.
I discovered an amazing thing ā€œwebapiā€ on webserver (only in local network)
You need login to webserver OZW and change ā€œsection=webapiā€. In webapi interface you can read all Values from ā€œmenutreeā€ and other things.
So my code for OZW672 with my Brƶtje BGB 38E looks like this: (configuration.yaml)
- platform: rest
    resource: http://192.168.X.X/api/auth/login.json?user=XXXXXX&pwd=XXXXXX
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2011
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2012
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2014
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2402
    unit_of_measurement: "%"
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2386
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2535
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2010
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2550
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2398
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2533
  - platform: rest
    resource_template: http://192.168.X.X/api/menutree/read_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2536
First step (only read Value) is finish, but i would like to next step, change Values per Api (URL).
If i test send some Values via webapi, its working - URL and ā€œwrite_datapoint.jsonā€
My idea is have some ā€œGeneric Thermostatā€ in ā€œlovelaceā€ and value send per button (this url must have format like this):
./api/menutree/write_datapoint.json?SessionId=XXXXXXXXXXXXX&Id=2011&Type=Numeric&Value=18 // Value from Thermostat in lovelace
Now I need your better experience how to send values via this URL API links and use ā€œwrite_datapoint.jsonā€ in OZW672 :slight_smile:
Thank you all and have a nice day
There i send my solution for Remote control (send values) to OZW672 (in my case Brƶtje with LMS14.002A100):
First i created in config -> helpers -> new input_number and input_select entities with Values: Comfort, Automatic, Reduced
add rest_command to configuration.yaml:
rest_command:
  odeslatdokotleteplotu:
    url: 'http://192.168.X.X/api/menutree/write_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2011&Type=Numeric&Value={{ states.input_number.nastaveni_teploty_kotle.state }}'
  odeslatdokotleutlumovouteplotu:
    url: 'http://192.168.X.X/api/menutree/write_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2012&Type=Numeric&Value={{ states.input_number.utlumova_teplota_kotle.state }}'
With send Value ā€œType of Operationā€ is little more complicated, beceause you need ā€œtranslateā€ text string to ā€œenumeration valueā€
  odeslatdokotle_druhprovozu:
    url: >
         {% if is_state("input_select.kotel_druh_provozu", "Útlum") %}
           http://192.168.X.X/api/menutree/write_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2010&Type=Enumeration&Value=2
         {%-elif is_state("input_select.kotel_druh_provozu", "Automatický") %}
           http://192.168.X.X/api/menutree/write_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2010&Type=Enumeration&Value=1
         {%-elif is_state("input_select.kotel_druh_provozu", "KomfortnĆ­") %}
           http://192.168.X.X/api/menutree/write_datapoint.json?SessionId={{ states.sensor.sid_token.state }}&Id=2010&Type=Enumeration&Value=3
         {% else %}
              none
         {% endif %}
Now you need start this rest_command services in automations.yaml:
- id: '1589750127952'
  alias: odeslat_teplotu_do_kotle
  description: Odeslat teplotu do kotle
  - entity_id: input_number.nastaveni_teploty_kotle
    platform: state
  condition: []
  - data: {}
    service: rest_command.odeslatdokotleteplotu
- id: odeslat_druhprovozu_dokotle
  alias: Odeslat druh provozu do kotle
  - entity_id: input_select.kotel_druh_provozu
    platform: state
  - data: {}
    service: rest_command.odeslatdokotle_druhprovozu
- id: odeslat_utlumovouteplotu_dokotle
  alias: Odeslat Ćŗtlumovou teplotu do kotle
  - entity_id: input_number.utlumova_teplota_kotle
    platform: state
  - data: {}
    service: rest_command.odeslatdokotleutlumovouteplotu
If you like this Solution, you can donate me on PayPal (joke) :slight_smile: :laughing:
Great job, Venca !
I own a CTA heat pump with a siemens RVS61.843. I’ve just installed the OZW672 server and updated it to last version (10.0). I’m able to connect it with HA and get the token address.
I can access to the webapi page (on OWZ672 webserver) that venca.kratky was referering to in a previous post.
But is there a way to find all the id avalaible from device connected to the OZW672 (RVS61.843 in my case) ?
It is possible (from the webapi page on the server) to enter a random id and write the corresponding value in an excel file for exemple, but it will take a hell as this process has to be done one by one id…
Thank you
Hi, after firmware update to Version 10 you have to enable http access in OZW672- Setup- Communications - Services -
And there Web Access via HTTP
After upgrading is this again disabled
Thank you for your reply.
I have already activated http access and I’m able to access to the webapi page.
But my question is just to know where do you find the Id resource in the webserver OZW672 ?
For example, where do you find that the Id=2536 is corresponding to kotel_venkovni_teplota
Thank you !
There i try images manual …
Wow It’s clear and everything is working nicely !
Big thank you to have taken the time to answer me !!
Very big thanks to you.
I begin in HA and thanks to you I made my first automation, my first rest command, I discovered powerful Siemens WebApi and now my HeatPump Atlantic work in HA.
