Signal Messenger Add-On + NodeRed
The How-To Explanation that I never found anywhere else
So, you want to integrate a Signal Messenger account into your Home Assistant instance, and you got to the point where you could send, but not receive, or were entirely disappointed with the lag and how slow it is.
Read on!
The instructions are simple and easy to follow. But don’t do it!
Skip ahead to the Signal CLI REST API installation instructions.
Once you have the Signal Messenger Add-On installed, go into the Configuration.
Choose the mode: json-rpc.
Toggle OFF Auto_Receive
Change the External Port number if necessary. My instance is already using 8080 somewhere else. So I changed the Signal Docker port to 7465. (That’s SGNL on a touchtone phone.)
Go to Info and Start the Signal Messenger Add-On.
Have a look at the Log on Start Up. It should look like this:
The next few steps are required to associate your Signal Add-On with a phone number. This can be a totally new number on Signal (probably the best option), or it can be an existing number (that will be shared with your phone). The downside of linking your HA Signal is that you would just be sending messages to yourself.
The instructions are straight forward and have all the necessary steps in detail, should you run into issues. Do all of these from a Terminal, and remember to use the IP of your HA Instance (the external IP, or hostname/domain name), and the port number you defined in the configuration.
Once you have successfully registered your HA with Signal and have completed some of the preliminary checks, and the logs are not throwing any 400 or 404 errors.
Lucky for you, I have Noded out a full Signal CLI REST API Flow for you to import. It’s fully Commented and will provide most of the commands listed. Some of the API calls just didn’t succeed, and I don’t know why. But it’s not really a problem because the main functions of sending and receiving should be working.
The most important piece of information that is not at all mentioned in the official documentations found on HA or the Signal CLI REST API, or the Signal-CLI githubs is this: when in json-rpc mode, all interactions with the Add-On are sent by HTTP, with the exception of RECEIVING MESSAGES, which is available only on a WebSocket connection.
In modes “normal” or “native”, sending and receiving are often delayed and quite sluggish, as the engine spins up for each service call. But in json-rpc mode, the receiving of messages is through the always-on always-connected WebSocket.
After importing the Flow into your NodeRed, be sure to add the REQUIRED Global Env Variables; these are used throughout the Nodes in the Flow.
Also be sure to edit the WebSocket Node in the Messages group to reflect your Signal resource, port, and Signal Phone Number.
When you are using Terminal to do the initial setup, it will be to your HA external IP.
However, when NodeRed is communicating with Signal, on http:// REST API calls or on the ws:// WebSocket, this is all happening inside the Docker network in HA. Therefore the URL in NodeRed is the hostname of the Signal Docker. This is viewable on the Info tab of the add-on.
Even if you have set a different port for Signal, the internal network of Docker maintains the default port of 8080 for communicating with the Signal Messenger host.
Once you’ve come this far… Just start with sending and receiving messages and watching the debug. You should be able to expand the json objects and locate the paths with which you will build your automations and notifications in NodeRed.
The Flow is too long for a single post. I will post it in two replies.
This is Part 1 of the Flow
[{"id":"3240b1abdd2b9cc0","type":"tab","label":"Signal Messenger","disabled":false,"info":"","env":[]},{"id":"d09b4bf0ac40a1dc","type":"group","z":"3240b1abdd2b9cc0","name":"Messages","style":{"stroke":"#000000","fill":"#c8e7a7","label":true,"color":"#000000","label-position":"ne"},"nodes":["6d93e88b1e70eb79","a8bf417e2fb1d44c","399891f08c181bbf","97005b3edc34119d","44e4482edd7b0bbc","d416b6b2783e0d95","3c7b6b7dfc073e13","f24961571f4ca048","f9e1c2353e30f3da","01dd4f0ba1caa84b","f84a642126c6f401","216864cd48324378","1c1966db6bdd1151","ab541d059c27634e","acd36385bf216bc3","320c907ae16bd118"],"x":54,"y":579,"w":732,"h":482},{"id":"66db6ed8538aa25a","type":"group","z":"3240b1abdd2b9cc0","name":"Group Actions","style":{"stroke":"#000000","fill":"#ffdf7f","label":true,"color":"#001f60"},"nodes":["1077d1a6a70caeb1","37791c81deae0edb","46bcf90a0c8c5e14","0444b4fdb1a44883","4bf25e1da4c3cf2f","080435febec3faa7","3d4d7ad29478f56f","7463dd958cad9c7d","eacf128896ef1d75","5ce5f6ac9ccecc3f","1883c673cc7fd875","05901559b046735e","9fd5cc8da301bb2a","400e1991256db001","578358ebd81506ab","b314a6dd55b70dfc","3f9204a78046e854","7108f971c36a609b","3692f4e607a89fc3","33076447e5040d7f","03d90bdba7100ff3","0569fd357eb939ce","3086665b284694cf","64d3c119e5a4bed6","df6e6efe7336b61d","71592ea3d174d75e","2df2d27a5788fd44","a197340e95bff72d","868d717057115bfc","c63177f56c67d4de","68eaded31b51bfc3","426b58641c07dab0","45b5f4df745f0df8","6d02d61fbfc0fbb6","2762a409bd366916","b1cc87736ccc0151","2d65fa8550e0938f","7d8a22d94d17f39f","655ba30a30919e17","7277a91a2681e24f","f03880a97c602c24","5928816a80a090eb","bcade1473470f263","cb36c6bc822b38cf","4eb442f87a5a74a3","70708a6092ef09b0","cc329acbaba3b3a7","bae8df465e5bef69","bec501a8bbdfca40"],"x":814,"y":99,"w":852,"h":1282},{"id":"9960202b1208ef7b","type":"group","z":"3240b1abdd2b9cc0","name":"General","style":{"stroke":"#000000","fill":"#7fb7df","label":true,"label-position":"ne","color":"#000000"},"nodes":["17ecccb972234070","3335a5836a1f1d6f","552a23c432b48a2f","a06e918627829672","eece0e5e26bc8f93","e0aae9e41e8b04fe","80dfeddd3f3a95a7","761ba4aade07aff0","4d4ba6ef3330ae84","95bdf43c41020987","e8b592c436e335b9","82e969976e44571f","c680452b6921318c","a55e92518369399f","8a7e0e2728dd3cf7","3a0880a3662d0445"],"x":54,"y":99,"w":732,"h":422},{"id":"44f2778d817fd3a9","type":"group","z":"3240b1abdd2b9cc0","name":"Trust Identities","style":{"stroke":"#000000","fill":"#d1d1d1","label":true,"label-position":"ne","color":"#000000"},"nodes":["b2f5dd6e03a136f3","eb8fe74b94ee0f79","7a915afc8c35fc67","9bb14c15cb8a65d9","41b98669873ded1b","9d90428694ebd6f5","ee38b66a74042f61","5a8096c460ab3555","c6dbc0b68361dd92"],"x":74,"y":1099,"w":692,"h":282},{"id":"7f3749c392037095","type":"group","z":"3240b1abdd2b9cc0","name":"Contacts","style":{"stroke":"#000000","fill":"#ffff7f","label":true,"label-position":"ne","color":"#000000"},"nodes":["c8f1cc833c2218a9","ba5d158fce2fd0c4","bd54b84bc8341dba","4c8bc2f9ab0b8fe1","f969efddaf409890","8fef4d9e01276f7f","dfc9a9321740fd56","154cf7a88fd8de54","766b3aef36c93507"],"x":54,"y":1419,"w":992,"h":282},{"id":"6d93e88b1e70eb79","type":"inject","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"PUT Typing Indicator","props":[{"p":"url","v":"$env('signal_url') & '/v1/typing-indicator/' & $env('signal_num')","vt":"jsonata"},{"p":"method","v":"PUT","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"recipient\":$env('signal_snd')}","payloadType":"jsonata","x":200,"y":660,"wires":[["a8bf417e2fb1d44c"]]},{"id":"a8bf417e2fb1d44c","type":"http request","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":430,"y":660,"wires":[["399891f08c181bbf"]]},{"id":"399891f08c181bbf","type":"debug","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Typing Indicator","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":660,"wires":[]},{"id":"97005b3edc34119d","type":"comment","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Turn ON Typing Indicator for Specified Recipient","info":"","x":320,"y":700,"wires":[]},{"id":"44e4482edd7b0bbc","type":"inject","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"DELETE Typing Indicator","props":[{"p":"url","v":"$env('signal_url') & '/v1/typing-indicator/' & $env('signal_num')","vt":"jsonata"},{"p":"method","v":"DELETE","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"recipient\":$env('signal_snd')}","payloadType":"jsonata","x":210,"y":760,"wires":[["d416b6b2783e0d95"]]},{"id":"d416b6b2783e0d95","type":"http request","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":430,"y":760,"wires":[["3c7b6b7dfc073e13"]]},{"id":"3c7b6b7dfc073e13","type":"debug","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Typing Indicator","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":760,"wires":[]},{"id":"f24961571f4ca048","type":"comment","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Turn OFF Typing Indicator for Specified Recipient","info":"","x":320,"y":800,"wires":[]},{"id":"f9e1c2353e30f3da","type":"inject","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"POST Send a Message","props":[{"p":"url","v":"$env('signal_url') & '/v2/send'","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\t   \"number\": $env('signal_num'),\t   \"recipients\":[$env('signal_snd')],\t   \"message\":\"Sending a Test Message.\"\t}","payloadType":"jsonata","x":200,"y":860,"wires":[["01dd4f0ba1caa84b"]]},{"id":"01dd4f0ba1caa84b","type":"http request","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":430,"y":860,"wires":[["f84a642126c6f401"]]},{"id":"f84a642126c6f401","type":"debug","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Typing Indicator","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":860,"wires":[]},{"id":"216864cd48324378","type":"comment","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Send a Message to the Defined Recipient(s)","info":"","x":310,"y":900,"wires":[]},{"id":"1077d1a6a70caeb1","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"PUT Update Group","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp')","vt":"jsonata"},{"p":"method","v":"PUT","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"description\":\"Update Description HERE\",\"name\":\"Update Name HERE\"}","payloadType":"json","x":950,"y":500,"wires":[["37791c81deae0edb"]]},{"id":"37791c81deae0edb","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":500,"wires":[["46bcf90a0c8c5e14"]]},{"id":"46bcf90a0c8c5e14","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Update Group Name & Description","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1480,"y":500,"wires":[]},{"id":"0444b4fdb1a44883","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Update Group Name and Description.","info":"","x":1050,"y":540,"wires":[]},{"id":"4bf25e1da4c3cf2f","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"DELETE Group","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp')","vt":"jsonata"},{"p":"method","v":"DELETE","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":940,"y":600,"wires":[["080435febec3faa7"]]},{"id":"080435febec3faa7","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":600,"wires":[["3d4d7ad29478f56f"]]},{"id":"3d4d7ad29478f56f","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Delete Group by ID","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1530,"y":600,"wires":[]},{"id":"7463dd958cad9c7d","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Delete Group by ID.","info":"","x":990,"y":640,"wires":[]},{"id":"eacf128896ef1d75","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"POST Add Group Admins","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp') & '/admins'","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"admins\":[\"add admins by phone number here\",\"like this --->\",\"+CountryCodeAreaCodePhoneNumber\",\"+12125551234\"]}","payloadType":"json","x":970,"y":700,"wires":[["5ce5f6ac9ccecc3f"]]},{"id":"5ce5f6ac9ccecc3f","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":700,"wires":[["1883c673cc7fd875"]]},{"id":"1883c673cc7fd875","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Add Group Admins","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1530,"y":700,"wires":[]},{"id":"05901559b046735e","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Add Admins to existing Group","info":"","x":1020,"y":740,"wires":[]},{"id":"9fd5cc8da301bb2a","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"DELETE Group Admins","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp') & '/admins'","vt":"jsonata"},{"p":"method","v":"DELETE","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"admins\":[\"delete admins by phone number here\",\"like this --->\",\"+CountryCodeAreaCodePhoneNumber\",\"+12125551234\"]}","payloadType":"json","x":960,"y":800,"wires":[["400e1991256db001"]]},{"id":"400e1991256db001","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":800,"wires":[["578358ebd81506ab"]]},{"id":"578358ebd81506ab","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Delete Group Admins","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1520,"y":800,"wires":[]},{"id":"b314a6dd55b70dfc","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Add Admins to existing Group","info":"","x":1020,"y":840,"wires":[]},{"id":"3f9204a78046e854","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"POST Block Group","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp') & '/block'","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":950,"y":900,"wires":[["7108f971c36a609b"]]},{"id":"7108f971c36a609b","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":900,"wires":[["3692f4e607a89fc3"]]},{"id":"3692f4e607a89fc3","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Block Group","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1550,"y":900,"wires":[]},{"id":"33076447e5040d7f","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Block the Specified Group","info":"","x":1010,"y":940,"wires":[]},{"id":"03d90bdba7100ff3","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"POST Join Group","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp') & '/join'","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":940,"y":1000,"wires":[["0569fd357eb939ce"]]},{"id":"0569fd357eb939ce","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":1000,"wires":[["3086665b284694cf"]]},{"id":"3086665b284694cf","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Join Group","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1550,"y":1000,"wires":[]},{"id":"64d3c119e5a4bed6","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Join the Specified Group","info":"","x":1010,"y":1040,"wires":[]},{"id":"df6e6efe7336b61d","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"POST Add Group Members","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp') & '/members'","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"},{"p":"payoad","v":"{\"members\":[\"add members by phone number here\",\"like this --->\",\"+CountryCodeAreaCodePhoneNumber\",\"+12125551234\"]}","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":980,"y":1100,"wires":[["71592ea3d174d75e"]]},{"id":"71592ea3d174d75e","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":1100,"wires":[["2df2d27a5788fd44"]]},{"id":"2df2d27a5788fd44","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Add Group Members","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1520,"y":1100,"wires":[]},{"id":"a197340e95bff72d","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Add new Members to the Specified Group","info":"","x":1060,"y":1140,"wires":[]},
This is Part Two of the Flow
Combine them in order in a json file and import to NodeRed
{"id":"868d717057115bfc","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"DELETE Group Members","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp') & '/members'","vt":"jsonata"},{"p":"method","v":"DELETE","vt":"str"},{"p":"payoad","v":"{\"members\":[\"delete members by phone number here\",\"like this --->\",\"+CountryCodeAreaCodePhoneNumber\",\"+12125551234\"]}","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":970,"y":1200,"wires":[["c63177f56c67d4de"]]},{"id":"c63177f56c67d4de","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":1200,"wires":[["68eaded31b51bfc3"]]},{"id":"68eaded31b51bfc3","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Remove Group Members","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1510,"y":1200,"wires":[]},{"id":"426b58641c07dab0","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Remove Members from the Specified Group","info":"","x":1070,"y":1240,"wires":[]},{"id":"45b5f4df745f0df8","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"POST Quit Group","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp') & '/quit'","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":940,"y":1300,"wires":[["6d02d61fbfc0fbb6"]]},{"id":"6d02d61fbfc0fbb6","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":1300,"wires":[["2762a409bd366916"]]},{"id":"2762a409bd366916","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Quit Group","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1550,"y":1300,"wires":[]},{"id":"b1cc87736ccc0151","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Quit the Specified Group","info":"","x":1010,"y":1340,"wires":[]},{"id":"2d65fa8550e0938f","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"GET Groups","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num')","vt":"jsonata"},{"p":"method","v":"GET","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":930,"y":200,"wires":[["7d8a22d94d17f39f"]]},{"id":"7d8a22d94d17f39f","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":200,"wires":[["655ba30a30919e17"]]},{"id":"655ba30a30919e17","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"List All Groups","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1420,"y":200,"wires":[]},{"id":"7277a91a2681e24f","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"List all Signal Groups","info":"","x":1000,"y":240,"wires":[]},{"id":"f03880a97c602c24","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"POST Groups","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num')","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"members\":[\"ADD\",\"NEW\",\"MEMBERS\",\"HERE\",\"FORMATTED AS:\",\"+CountryCodeAreaCodePhoneNumber\",\"+12125551234\"],\"name\":\"Test Group\"}","payloadType":"json","x":930,"y":300,"wires":[["5928816a80a090eb"]]},{"id":"5928816a80a090eb","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":300,"wires":[["bcade1473470f263"]]},{"id":"bcade1473470f263","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Create New Group","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1430,"y":300,"wires":[]},{"id":"cb36c6bc822b38cf","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Create New Group.  Edit POST Group Inject Node msg.data as necesssary.","info":"","x":1160,"y":340,"wires":[]},{"id":"4eb442f87a5a74a3","type":"inject","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"GET Group List","props":[{"p":"url","v":"$env('signal_url') & '/v1/groups/' & $env('signal_num') & '/' & $env('signal_grp')","vt":"jsonata"},{"p":"method","v":"GET","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":940,"y":400,"wires":[["70708a6092ef09b0"]]},{"id":"70708a6092ef09b0","type":"http request","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":1210,"y":400,"wires":[["cc329acbaba3b3a7"]]},{"id":"cc329acbaba3b3a7","type":"debug","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"List Defined Group","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1430,"y":400,"wires":[]},{"id":"bae8df465e5bef69","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"List Group Information","info":"","x":1000,"y":440,"wires":[]},{"id":"17ecccb972234070","type":"debug","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"About","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":140,"wires":[]},{"id":"3335a5836a1f1d6f","type":"http request","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":430,"y":140,"wires":[["17ecccb972234070"]]},{"id":"552a23c432b48a2f","type":"inject","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"GET About","props":[{"p":"url","v":"$env('signal_url') & '/v1/about'","vt":"jsonata"},{"p":"method","v":"GET","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":160,"y":140,"wires":[["3335a5836a1f1d6f"]]},{"id":"a06e918627829672","type":"inject","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"GET Account Configuration","props":[{"p":"url","v":"$env('signal_url') & '/v1/configuration/' & $env('signal_num') & '/settings'","vt":"jsonata"},{"p":"method","v":"GET","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":220,"y":240,"wires":[["eece0e5e26bc8f93"]]},{"id":"eece0e5e26bc8f93","type":"http request","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":430,"y":240,"wires":[["e0aae9e41e8b04fe"]]},{"id":"e0aae9e41e8b04fe","type":"debug","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Account Configuration","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":240,"wires":[]},{"id":"80dfeddd3f3a95a7","type":"inject","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"GET Health","props":[{"p":"url","v":"$env('signal_url') & '/v1/health'","vt":"jsonata"},{"p":"method","v":"GET","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":440,"wires":[["761ba4aade07aff0"]]},{"id":"761ba4aade07aff0","type":"http request","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":430,"y":440,"wires":[["4d4ba6ef3330ae84"]]},{"id":"4d4ba6ef3330ae84","type":"debug","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Health Check","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":440,"wires":[]},{"id":"95bdf43c41020987","type":"comment","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"General information about the Signal API","info":"","x":280,"y":180,"wires":[]},{"id":"e8b592c436e335b9","type":"comment","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Account specific settings","info":"","x":230,"y":280,"wires":[]},{"id":"82e969976e44571f","type":"comment","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Health Check : responds 204 when healthy","info":"","x":280,"y":480,"wires":[]},{"id":"c680452b6921318c","type":"inject","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"GET Accounts","props":[{"p":"url","v":"$env('signal_url') & '/v1/accounts'","vt":"jsonata"},{"p":"method","v":"GET","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":340,"wires":[["a55e92518369399f"]]},{"id":"a55e92518369399f","type":"http request","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":430,"y":340,"wires":[["8a7e0e2728dd3cf7"]]},{"id":"8a7e0e2728dd3cf7","type":"debug","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"Accounts","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":680,"y":340,"wires":[]},{"id":"3a0880a3662d0445","type":"comment","z":"3240b1abdd2b9cc0","g":"9960202b1208ef7b","name":"List all accounts linked or registered.","info":"","x":280,"y":380,"wires":[]},{"id":"b2f5dd6e03a136f3","type":"inject","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"GET Identities","props":[{"p":"url","v":"$env('signal_url') & '/v1/identities/' & $env('signal_num')","vt":"jsonata"},{"p":"method","v":"GET","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":190,"y":1200,"wires":[["eb8fe74b94ee0f79"]]},{"id":"eb8fe74b94ee0f79","type":"http request","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":450,"y":1200,"wires":[["7a915afc8c35fc67"]]},{"id":"7a915afc8c35fc67","type":"debug","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"Identities","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":1200,"wires":[]},{"id":"9bb14c15cb8a65d9","type":"comment","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"List all Identities","info":"","x":240,"y":1240,"wires":[]},{"id":"41b98669873ded1b","type":"inject","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"PUT Trust Identity","props":[{"p":"url","v":"$env('signal_url') & '/v1/identities/' & $env('signal_num') & '/trust/' & $env('signal_snd')","vt":"jsonata"},{"p":"method","v":"PUT","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\t   \"trust_all_known_keys\": false,\t   \"verified_safety_number\": $env('safety_num')\t}","payloadType":"jsonata","x":210,"y":1300,"wires":[["9d90428694ebd6f5"]]},{"id":"9d90428694ebd6f5","type":"http request","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":450,"y":1300,"wires":[["ee38b66a74042f61"]]},{"id":"ee38b66a74042f61","type":"debug","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"Trust Identity","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":1300,"wires":[]},{"id":"5a8096c460ab3555","type":"comment","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"Trust Specified Identity with Safety Number","info":"","x":330,"y":1340,"wires":[]},{"id":"c8f1cc833c2218a9","type":"comment","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"Search for Specified User","info":"","x":250,"y":1560,"wires":[]},{"id":"ba5d158fce2fd0c4","type":"inject","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"POST Synchronize Contacts","props":[{"p":"url","v":"$env('signal_url') & '/v1/contacts/' & $env('signal_num') & '/sync'","vt":"jsonata"},{"p":"method","v":"POST","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":220,"y":1520,"wires":[["bd54b84bc8341dba"]]},{"id":"bd54b84bc8341dba","type":"http request","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":450,"y":1520,"wires":[["4c8bc2f9ab0b8fe1"]]},{"id":"4c8bc2f9ab0b8fe1","type":"debug","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"Synchronize Contacts","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":1520,"wires":[]},{"id":"f969efddaf409890","type":"comment","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"Add a New Contact or Update Existing Contact","info":"","x":320,"y":1660,"wires":[]},{"id":"8fef4d9e01276f7f","type":"inject","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"PUT Add New or Update Contact","props":[{"p":"url","v":"$env('signal_url') & '/v1/contacts/' & $env('signal_num')","vt":"jsonata"},{"p":"method","v":"PUT","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\t   \"expiration_in_seconds\": 7200,\t   \"name\": $env('contact_name'),\t   \"recipient\": $env('signal_snd')\t}","payloadType":"jsonata","x":230,"y":1620,"wires":[["dfc9a9321740fd56"]]},{"id":"dfc9a9321740fd56","type":"http request","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"Signal API","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""}],"x":450,"y":1620,"wires":[["154cf7a88fd8de54"]]},{"id":"154cf7a88fd8de54","type":"debug","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"Update Contacts","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":1620,"wires":[]},{"id":"b1bdc6b343aae5ec","type":"comment","z":"3240b1abdd2b9cc0","name":"REQUIRED: Define Global Environmental Variables: \"signal_url\" = \"http://1315902c-signal-messenger:8080\", \"signal_num\" = {{your registered Signal phone number}}","info":"","x":610,"y":60,"wires":[]},{"id":"bec501a8bbdfca40","type":"comment","z":"3240b1abdd2b9cc0","g":"66db6ed8538aa25a","name":"REQUIRED: Define Global Environmental Variable: \"signal_grp\" = {{group.ID}}","info":"","x":1130,"y":140,"wires":[]},{"id":"1c1966db6bdd1151","type":"comment","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"REQUIRED: Define Global Environmental Variable: \"signal_snd\" = {{phone number of recipient}}","info":"","x":430,"y":620,"wires":[]},{"id":"c6dbc0b68361dd92","type":"comment","z":"3240b1abdd2b9cc0","g":"44f2778d817fd3a9","name":"REQUIRED: Define Global Environmental Variable: \"safety_num\" = {{safety number}}","info":"","x":390,"y":1140,"wires":[]},{"id":"766b3aef36c93507","type":"comment","z":"3240b1abdd2b9cc0","g":"7f3749c392037095","name":"REQUIRED: Define Global Environmental Variables: \"signal_snd\" = {{phone number of recipient}}, \"contact_name\" = {{name of your contact}}","info":"","x":550,"y":1460,"wires":[]},{"id":"ab541d059c27634e","type":"websocket in","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Signal Receive","server":"","client":"c7bcef6ada6d3c7f","x":280,"y":960,"wires":[["acd36385bf216bc3"]]},{"id":"acd36385bf216bc3","type":"debug","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Signal Messages Received","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":560,"y":960,"wires":[]},{"id":"320c907ae16bd118","type":"comment","z":"3240b1abdd2b9cc0","g":"d09b4bf0ac40a1dc","name":"Open this WebSocket Node and edit the URL to include your Signal Number","info":"","x":430,"y":1020,"wires":[]},{"id":"c7bcef6ada6d3c7f","type":"websocket-client","path":"ws://1315902c-signal-messenger:8080/v1/receive/+yourSignalPhoneNumberHere","tls":"","wholemsg":"true","hb":"0","subprotocol":""}]
Hi Lewis, a beginners question… REQUIRED: Define Global Environmental Variables: “signal_url” = “http://1315902c-signal-messenger:8080”, “signal_num” = {{your registered Signal phone number}}… where to define… can i have a sample ?
When in the Node-RED dashboard, click on the hamburger menu in the upper right, then click on Settings.
In the pop-up window there are four stacked tabs on the left side, View, Palette, Keyboard, Environment
Select Environment
Add key value (str) pairs to match what I’ve entered in the comment bubbles.
Start here:
Signal for HA on GitHub
Follow the installation instructions.
Hi Lewis,
yes, thank you
Part 1 is working now.
1.- added in REPOSITORIE: the URL: GitHub - haberda/hassio_addons: hopefully useful hassio addons
then i can see the add-on Signal-Messenger
Hi Lewis,
when i correct you understand,
i set the value in “Environment”
Now how can do a basic test that i received the message?
Hi Lewis,
i add the configuration for notify.signal and tried a test, but i don’t receive again anything :frowning:
Any suggestion for me?
SORRY, i cannot more add new reply. - i reached the limit
Hi Lewis,
thank you very much for your quickly reply.
when you wrote: Use the inject nodes to send yourself a message, and then reply to that message from your phone. → i need to add a new “inject nodes” in CANVAS and configure my phone number OR i need to use a specific “inject node” that already are in CANVAS.
Sorry my questions, today is my first day with Node RED :slight_smile:
Assuming you have successfully registered a phone number with Signal, then you should be able to test everything from my Flow within Node-Red.
When you are in Node-Red, be sure to have the debug window in view (on the right side of the screen, the little bug icon).
The debug window/console will log all the messages for sending and receiving, and also show errors if there are any.
Lewis - This is great stuff! I just wanted to send a quick thanks for posting.
Lewis -
As a follow up, I wanted ti let you know that I am able to control HA remotely using Signal and the local Agent service. I even wrote a custom intent that allows me to take a Signal message and broadcast it on the home speakers via TTS. My wife loved it when I had the service ask one of our kids to do something and then call us. Saved us from trying to get them to answer the phone!
Daniel
Daniel
What a great idea! I was so focussed on just making it work. And the best I got to was using geotags to have HA send a notification upon returning to “home” to provide door lock status, and then permit unlocking with a text response.
It was obviously merely for my own enjoyment, as my family members are satisfied with using Apple Home to unlock / lock doors.
And yet, I frequently would go through a cumbersome process of manually typing in text to a service call to make announcements on Alexa.
Your solution is so much better!
Thanks for the feedback. It takes a lot of time to find solutions, and more time to document it in a way that others can understand. So it’s nice to know that other people find it all useful.
(EDIT: I had a breakthrough on how to create multiple Intent slots. It apparently needs at least one word between slots to work. In any event, this update now allows for Signal messages to be targeted to a particular person, or more generically ask/tell)
Well, please allow me to return the favor and get you started!
I have a penchant to P.G. Wodehouse, which explains some of the response returns. I do enjoy, though, that not every response is the same.
I would love to hear how you get on with this.
This is the custom intent. The script.message_announcement is a custom action that works with my specific speakers to produce the TTS, so you will need to change that. Feel free to leave my name in the announcement message, although that may prove awkward with the family.
alias: Announcement intent
description: ""
triggers:
  - trigger: conversation
    command:
      - tell {person} this {message}
      - tell {message}
    enabled: true
    command:
      - ask {person} this {message}
      - ask {message}
    command:
      - (hello|greetings)
      - good (morning|afternoon|evening|day)
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - message
        sequence:
          - action: script.message_announcement
            metadata: {}
              message: |-
                {{ trigger.slots.person }}, Daniel {{ [
                  "has a message for you",
                  "would like you to know",
                  "has said",
                ] | random
                }}, {{ trigger.slots.message }}
          - set_conversation_response: |-
                "I have passed on the message to",
                "I have notified",
                "I have given your message to",
                "I announced it to"
              ] | random }} {{ trigger.slots.person }}
        alias: Announce
      - conditions:
            id:
              - question
        sequence:
            metadata: {}
              message: |-
                  "has a question",
                  "wishes to know",
                  "has asked",
                ] | random
            enabled: true
                "I have passed on the question to",
                "I have asked",
                "I have relayed your query to",
                "I asked"
        alias: Ask
      - conditions:
            id:
              - greetings
        sequence:
          - alias: Greetings
            choose:
              - conditions:
                  - condition: time
                    after: "04:00:00"
                    before: "11:59:00"
                sequence:
                  - set_conversation_response: Good morning
                alias: Good morning
              - conditions:
                  - condition: time
                    after: "12:00:00"
                    before: "16:59:00"
                sequence:
                  - set_conversation_response: Good afternoon
                alias: Good afternoon
              - conditions:
                  - condition: time
                    after: "17:00:00"
                    before: "03:59:00"
                sequence:
                  - set_conversation_response: Good evening
                alias: Good evening
        alias: Greeting
mode: single
This is my Signal response handler. It will publish to the HA Assistand relay the response back to you in text. Personally, I find this a far more secure and private means of interacting with one’s HA that the usual manner of exposing through some cloud service. Anything you be able to control with Assist, you can control over Signal.
alias: "Jarvis: Signal"
description: ""
triggers:
  - trigger: mqtt
    topic: signal/received
conditions: []
actions:
  - variables:
      command: "{{ trigger.payload_json.message|lower }}"
  - action: conversation.process
    metadata: {}
      agent_id: conversation.home_assistant
      text: "{{ command }}"
    response_variable: agent
  - action: mqtt.publish
    metadata: {}
      evaluate_payload: false
      qos: 0
      topic: signal/send
      payload: "{{ agent.response.speech.plain.speech }}"
mode: single
My next step is to add filtering for my wife and me. I want to have slightly different experiences depending on who sends the message (it also creates yet another layer of security by locking down to whitelisted numbers). This way, the TTS can specific if either my wife or I was responsible for the audio announcement.
Hope that gives you some new ideas!
Hi Lewis,
great work! big thank you!
The HomeAssistant integration did not work for me… (Home Assistant in docker and no addons)
I think it has something to do with the ‘notify’ not working as expected…
However the case, after getting the Signal api docker up and running and using your guide and flows all works as expected!
Thank you for the awesome work!
Hey! That’s fantastic! I’m glad to read that my post was helpful for you.
About a year ago, I moved my Home Assistant from a repurposed Mac Mini (it was already 14 years old) to a new DIY PC server. I chose Unraid as my main OS (for the NAS).
I started with HA in a Docker container… but quickly found I was hitting many integration limitations.
I switched over to a VM inside Unraid, and that was the best choice for my setup.
So I can recall the frustrations of a Docker based HA instance.
I must admit, once I got Signal all working, I kind of abandoned it all. I worked on that mostly to learn something new.
I think the one feature the Signal integration was lacking was remote deletion of messages. I found I would have Signal chat sessions with very old notification messages that were just not very relevant. Manually deleting just became more of a chore.
I started doing some NodeRed flows which would respond to answers. But that got super complicated quickly. I had considered folding it all into an LLM, but as I mentioned, I soon moved on to other things.
Anyway, thanks the compliment !
