SignalRGB Integration
I created a new integration for SignalRGB so that you can control your RGBeez from HASS! With this integration, your system will become a light entity in HASS allowing you to control effects from automations. Vote for this API feature request if you want more features!
It’s not on HACS yet, but you can follow along with the README and add it as a custom repository.
Coming soon: A custom Lovelace widget for the integration
Sponsor the project here: Sponsor @hyperb1iss on GitHub Sponsors · GitHub :purple_heart:
Amazing work! I’m an OpenRGB user, but have been waiting for an HA integration before considering the move to SignalRGB.
I’ve just installed SignalRGB and have started configuring the integration. On the readme, it says to enable the SignalRGB API, but I cannot find the options in SignalRGB’s settings. Is this a PRO-only feature?
To answer my own question, a SignalRGB Pro subscription is required.
is there a way to unlink and link my wled via home assistant automation?
I cannot for the life of me figure out where to enable the API in signal rgb? i am on the newest beta, 2.3.109-beta i have pro… cannot find the setting anywhere!
it is auto-enabled once you update to the beta. You just have to add the integration and it should just work.
Got it working now, thank you! :slight_smile:
@hyperb1iss, really great work on this - it functions very well already while being in a beta state.
1 request i would have is, is there anyway to have a solid color that you can then use a RGB/CCT light in HA? right now it only reports the colors of BG and FG as attributes, would be great if when its solid it would report it like a normal rgb light.
Awesome. Have been able to sync my PC lights with the rest of my home studio setup all controlled via my stream deck thanks to this plugin.
For those that want to achieve the same, I had to create a new HTML effect for each of the eight different preset colours I have for my studio lights, then I set up an automation within HA to change effect via a trigger (when my other lights change basically). Took a bit of trial and error and manual coding.
All HTML effect creation and majority of the YAML code was done in Chat GPT. Sure makes life a lot easier.
Im working on my litle project TV Back Light. Is it possible for the signal from Nvidia Shield to be connected to SignalRGB using HA client? Of course, the return of the image to the TV would be loss-free quality 4K.
You might find something like this works better for what you have planned.
just installed today, trying to figure out how to use it :smiley:
The integration seems to have broken since the 2026.2 HA release, is this just me or have others seen the same thing? The integration no longer provides entities for my signalrgb instance.
Logger: homeassistant.components.light
Source: helpers/entity_platform.py:826
integration: Light (documentation, issues)
First occurred: February 4, 2026 at 7:00:34 PM (6 occurrences)
Last logged: 10:53:49 AM
Error adding entity light.signalrgb_01KFB9T7SKR0CPWZ4H31RGWGMB for domain light with platform signalrgb
Error adding entity light.signalrgb_01KGQ7Q8F0ZNN1D2GP26PTWWGV for domain light with platform signalrgb
Error adding entity light.signalrgb_01KGQ81WB64M905SSH48X3GPY7 for domain light with platform signalrgb
Error adding entity light.signalrgb_01KGQ84YWJ44YS3P6V41RAC29Q for domain light with platform signalrgb
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 826, in _async_add_entity
    raise HomeAssistantError(f"Invalid entity ID: {entity.entity_id}")
homeassistant.exceptions.HomeAssistantError: Invalid entity ID: light.signalrgb_01KFB9T7SKR0CPWZ4H31RGWGMB
I created PR#14 to fix this issue, if you’re impatient the fix is in my fork.
Looks like HA revertred the new behaviour in #162425, seems that this wasn’t the only integration impacted by the stricter entity ID enforcement.
I use SignalRGB primarily for movie screen ambience.
When SignalRGB is active, it fully takes over control of my lights. Home Assistant controls and scenes can be triggered, but their effects are immediately overwritten by SignalRGB.
Turning off the light.signalrgb_* entity in Home Assistant physically turns all the lights off, which isn’t what I want.
Is there a way to pause or temporarily disable SignalRGB’s control—without stopping the app or powering the lights off—so that Home Assistant can take control again?
