SIGTERM Recieved
I found this message SIGTERM Recieved in my log file this morning. How do I trace the origin of this message. I am including the other log messages for context
2019-05-16 19:09:55.030406 INFO pool_drop_lights: Turn on West Pool Drop Lights
2019-05-17 03:37:05.018018 INFO SIGTERM Recieved
2019-05-17 03:37:08.333132 INFO AppDaemon: Removing module /conf/apps/hello.py
2019-05-17 03:37:08.333451 INFO AppDaemon: Removing module /conf/apps/poolPumpMain.py
2019-05-17 03:37:08.333612 INFO AppDaemon: Removing module /conf/apps/lowOutsideTemp.py
2019-05-17 03:37:08.333761 INFO AppDaemon: Removing module /conf/apps/poolPumpRobot.py
2019-05-17 03:37:08.333995 INFO AppDaemon: Removing module /conf/apps/outside_temperature.py
2019-05-17 03:37:08.334152 INFO AppDaemon: Removing module /conf/apps/pool_drop_lights.py
2019-05-17 03:37:08.334298 INFO AppDaemon: Removing module /conf/apps/poolSaltCell.py
2019-05-17 03:37:08.334445 INFO AppDaemon: Removing module /conf/apps/poolLight.py
2019-05-17 03:37:08.334865 INFO AppDaemon: Terminating hello_world
2019-05-17 03:37:08.335146 INFO AppDaemon: Terminating poolPumpMain
2019-05-17 03:37:08.335378 INFO AppDaemon: Terminating lowOutsideTemp
2019-05-17 03:37:08.335584 INFO AppDaemon: Terminating poolPumpRobot
2019-05-17 03:37:08.335808 INFO AppDaemon: Terminating poolSaltCell
2019-05-17 03:37:08.336024 INFO AppDaemon: Terminating outside_temperature
2019-05-17 03:37:08.336292 INFO AppDaemon: Terminating pool_drop_lights
2019-05-17 03:37:08.336825 WARNING AppDaemon: Scheduler clock skew detected - delta = 3.336771011352539 - resetting
2019-05-17 03:37:08.337486 INFO AppDaemon: HASS: Disconnecting from Home Assistant
2019-05-17 03:37:08.338177 INFO AppDeamon Exited
2019-05-17 03:40:48.544362 INFO AppDaemon Version 3.0.2 starting
2019-05-17 03:40:48.557029 INFO Configuration read from: /conf/appdaemon.yaml
2019-05-17 03:40:48.591298 INFO AppDaemon: Starting Apps
2019-05-17 03:40:48.595697 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2019-05-17 03:40:49.201436 INFO AppDaemon: HASS: HASS Plugin Initializing
2019-05-17 03:40:49.203097 INFO AppDaemon: HASS: HASS Plugin initialization complete
2019-05-17 03:40:49.203652 INFO Starting Dashboards
2019-05-17 03:40:49.246314 INFO API is disabled
2019-05-17 03:40:49.253321 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-05-17 03:40:54.255904 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-05-17 03:40:59.259282 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-05-17 03:41:04.263152 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-05-17 03:41:09.276454 INFO AppDaemon: HASS: Connected to Home Assistant 0.86.4
2019-05-17 03:41:09.335670 INFO AppDaemon: Reading config
2019-05-17 03:41:09.365623 INFO AppDaemon: /conf/apps/apps.yaml added or modified
2019-05-17 03:41:09.366049 INFO AppDaemon: /conf/apps/apps.yaml added or modified
2019-05-17 03:41:09.366295 INFO AppDaemon: App 'hello_world' added
2019-05-17 03:41:09.366452 INFO AppDaemon: App 'poolPumpMain' added
2019-05-17 03:41:09.366598 INFO AppDaemon: App 'lowOutsideTemp' added
2019-05-17 03:41:09.366743 INFO AppDaemon: App 'poolPumpRobot' added
2019-05-17 03:41:09.367038 INFO AppDaemon: App 'poolSaltCell' added
2019-05-17 03:41:09.367199 INFO AppDaemon: App 'outside_temperature' added
2019-05-17 03:41:09.367349 INFO AppDaemon: App 'pool_drop_lights' added
2019-05-17 03:41:09.367533 INFO AppDaemon: App 'pool_light' added
2019-05-17 03:41:09.367952 INFO AppDaemon: Adding /conf/apps to module import path
2019-05-17 03:41:09.368452 INFO AppDaemon: Adding /conf/apps/@eaDir to module import path
2019-05-17 03:41:09.370484 INFO AppDaemon: Processing restart for HASS
2019-05-17 03:41:09.370947 INFO AppDaemon: Terminating hello_world
2019-05-17 03:41:09.371265 INFO AppDaemon: Terminating poolPumpMain
2019-05-17 03:41:09.371472 INFO AppDaemon: Terminating lowOutsideTemp
2019-05-17 03:41:09.371657 INFO AppDaemon: Terminating poolPumpRobot
2019-05-17 03:41:09.371840 INFO AppDaemon: Terminating poolSaltCell
2019-05-17 03:41:09.372390 INFO AppDaemon: Terminating outside_temperature
2019-05-17 03:41:09.372617 INFO AppDaemon: Terminating pool_drop_lights
2019-05-17 03:41:09.372822 INFO AppDaemon: Terminating pool_light
2019-05-17 03:41:09.373265 INFO AppDaemon: Loading App Module: /conf/apps/hello.py
2019-05-17 03:41:09.528298 INFO AppDaemon: Loading App Module: /conf/apps/poolPumpMain.py
2019-05-17 03:41:09.650025 INFO AppDaemon: Loading App Module: /conf/apps/lowOutsideTemp.py
2019-05-17 03:41:09.651232 INFO AppDaemon: Loading App Module: /conf/apps/poolPumpRobot.py
2019-05-17 03:41:09.662252 INFO AppDaemon: Loading App Module: /conf/apps/outside_temperature.py
2019-05-17 03:41:09.663472 INFO AppDaemon: Loading App Module: /conf/apps/pool_drop_lights.py
2019-05-17 03:41:09.664581 INFO AppDaemon: Loading App Module: /conf/apps/poolSaltCell.py
2019-05-17 03:41:09.708660 WARNING AppDaemon: No app description found for: /conf/apps/poolLight.py - ignoring
2019-05-17 03:41:09.709188 INFO AppDaemon: Initializing app hello_world using class HelloWorld from module hello
2019-05-17 03:41:10.929246 INFO hello_world: Hello from AppDaemon
2019-05-17 03:41:10.930749 INFO hello_world: You are now ready to run Apps!
2019-05-17 03:41:10.932163 INFO hello_world:
2019-05-17 03:41:10.933609 INFO hello_world:
2019-05-17 03:41:10.934273 INFO hello_world: 2019-05-17
2019-05-17 03:41:10.936155 INFO hello_world: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-05-17 03:41:10.936606 INFO AppDaemon: Initializing app poolPumpMain using class poolPumpMain from module poolPumpMain
2019-05-17 03:41:10.937752 INFO AppDaemon: Initializing app lowOutsideTemp using class lowOutsideTemp from module lowOutsideTemp
2019-05-17 03:41:10.938265 INFO AppDaemon: Initializing app poolPumpRobot using class poolPumpRobot from module poolPumpRobot
2019-05-17 03:41:11.051396 INFO poolPumpRobot: robot initialize ran
2019-05-17 03:41:11.051938 INFO AppDaemon: Initializing app poolSaltCell using class poolSaltCell from module poolSaltCell
2019-05-17 03:41:11.053071 INFO AppDaemon: Initializing app outside_temperature using class outside_temperature from module outside_temperature
2019-05-17 03:41:11.054140 INFO AppDaemon: Initializing app pool_drop_lights using class pool_drop_lights from module pool_drop_lights
2019-05-17 03:41:11.156139 INFO AppDaemon: Initializing app pool_light using class pool_light from module pool_light
2019-05-17 03:41:11.156379 WARNING AppDaemon: Unable to find module module pool_light - pool_light is not initialized
2019-05-17 03:41:12.167062 INFO AppDaemon: App initialization complete
