Hi to all, I’m working on a custom integration for the Silla Prism Solar Wallbox,
Integration Is in early stage and not yet stable but if someone is interested to try it or test it the link is the following:
Regards
Regards
Hi Stefano! Looking to do the same in MQTT yaml or Node red and just fine your integration! ![]()
You have to correct repositoy url behind the HACS button:
PS ottimo lavoro!
I added the integration and all is working good!
Hi, I have just try the integration, all feedback seems works, but not the command Pause and Limit max current
Hey guys
I wanted to try out this integration, but for some reason there are no MQTT settings on my Silla Prism. Although in the manual it says there should be. I am using the installer login. Anyone else experiencing this issue?
It moved to the new silla android/ios app
Ciao!
where? I can’t find it anywhere ![]()
Here the iOS link:
Ciao
