I had a Lidl Motion detector _TZ1800_fcdjzz3s running successfully using deconz integration. Recently I changed my home assistant configuration to ZHA. All elements were detected successfully except the _TZ1800_fcdjzz3s motion detector.
In deconz rest api:
“config”: {
“battery”: 100,
“duration”: 60,
“enrolled”: 1,
“on”: true,
“pending”: [],
“reachable”: true
“ep”: 1,
“etag”: “ef0b0ffc15dfd98944fd3bfe42270d69”,
“lastannounced”: “2022-12-02T12:42:43Z”,
“lastseen”: “2022-12-02T22:03Z”,
“manufacturername”: “_TZ1800_fcdjzz3s”,
“modelid”: “TY0202”,
“name”: “Presence 5”,
“state”: {
“lastupdated”: “2022-12-02T22:04:12.799”,
“lowbattery”: false,
“presence”: true,
“tampered”: false
“swversion”: “2019.12.12”,
“type”: “ZHAPresence”,
“uniqueid”: “ec:1b:bd:ff:fe:ab:8a:97-01-0500”
In ZHA the device is detected but the initialisation does not complete…
Untitled-3
107,90: Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x658C), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.Broadcast: 15>, address=<BroadcastAddress.RX_ON_WHEN_IDLE: 65533>), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=19, data=Serialized[b’\x81\x8ce\x97\x8a\xab\xfe\xff\xbd\x1b\xec\x80’], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-48)
108,12: New device 0x658c (ec:1b:bd:ff:fe:ab:8a:97) joined the network
109,2: [0x658c] Scheduling initialization
110,74: Received frame on uninitialized device from ep 0 to ep 0, cluster 19: b’\x81\x8ce\x97\x8a\xab\xfe\xff\xbd\x1b\xec\x80’
111,2: [0x658c:zdo] ZDO request ZDOCmd.Device_annce: [0x658C, ec:1b:bd:ff:fe:ab:8a:97, 128]
111,48: [0x658c:zdo] ZDO request ZDOCmd.Device_annce: [0x658C, ec:1b:bd:ff:fe:ab:8a:97, 128]
113,2: [0x658c] Requesting ‘Node Descriptor’
115,2: [0x658c] Extending timeout for 0x40 request
116,90: Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x658C), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=32770, data=Serialized[b’@\x00\x8ce\x02@\x80\x0b\x12RR\x00\x00,R\x00\x00’], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-48)
117,74: Received frame on uninitialized device from ep 0 to ep 0, cluster 32770: b’@\x00\x8ce\x02@\x80\x0b\x12RR\x00\x00,R\x00\x00’
118,2: [0x658c] Got Node Descriptor: NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4619, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)
119,2: [0x658c] Discovering endpoints
121,2: [0x658c] Extending timeout for 0x42 request
139,2: [0x658c] Extending timeout for 0x44 request
147,2: [0x658c] Extending timeout for 0x46 request
164,2: [0x658c] Discovering endpoints
166,2: [0x658c] Extending timeout for 0x48 request
170,2: [0x658c] Extending timeout for 0x4a request
180,2: [0x658c] Extending timeout for 0x4c request
182,2: [0x658c] Discovering endpoints
184,2: [0x658c] Extending timeout for 0x4e request
217,2: [0x658c] Extending timeout for 0x56 request
231,2: [0x658c] Extending timeout for 0x58 request
