Any progress on this? I mean, those products come in “starter packs” including the bridge, addressing people who put convenience over engineering. Support for the Lidl gateway, the same way as for the Hue bridges would be great.
I just tested the motion sensor and it seems to have a 65 seconds timeout, that is if there is no movement in that time, otherwise, it resets to another 65 seconds. This way too much time, anyone figured how to change that?
Was anyone able to integrate the led panel? I can’t find it under supported devices or any other info about it. During paring nothing happens in the log.
I’m not that familiar with iobroker but it seems it also uses z2m and states it as supported
Hi @Pst3cabral
I don’t know if you got this working. I managed to pair Lidl smart plug with Ikea GW, although you will still need something like HomeAssistant or Google Assistant to operate it. Ikea GW shows the devices with a “?”. I tried to capture some guidance here. Hope this helps!
Hi guys.
Is anyone else having trouble with the GU10 RGB Bulbs? I have 2 that I’m trying to use with ZHA, after hacking the gateway using this, and pairing works fine, but control is messed up:
when trying to set color temperature from the slider, I get cold-white in the middle of the slider and warm-white in any of the extremities
can’t set any color when clicking on the color wheel in HA, the color wheel disappears for a sec, then goes back and nothing happens
if I try to set a color like in previous step (and nothing happens), and then go into Integrations -> ZHA -> Devices, select the device and click Reconfigure Device, then the color gets applied immediately after reconfig…
@pippogsm I also see the same issues using ZHA and Lidl gateway for the Lidl lights (HG06106C, HG06104A). I spent some time searching for a quick solution, also for my Lidl doorbell, I concluded there is no proper support in ZHA.
I gave up and ordered a LAUNCHXL-CC1352P-2zigbee2mqtt adapter, which is supposed to properly support all my devices and have better options to customize/fix it yourself. I plan to use the Lidl gateway only as a router.
@stefand That’s a bummer. I tried making a custom quirk file for zha, and it successfully detects the bulb using that, but the behaviour is the same… maybe it needs some different mapping, but have no experience with this…
What I find strange is that I’ve paired another Lidl candle type RGB bulb, gets detected as ‘_TZ3000_odygigth’, and this one works just fine… The GU10 ones are ‘_TZ3000_kdpxju99’ type, and don’t work.
@stefand You can find details on how to do it here. I use hass io, so I had to use instructions from the bottom of that link, for docker. But it was a smooth ride, just be sure to unhide your homeassistant container in Portainer if you go this route.
