Silvercrest / Lidl Smarthome
Lidl ZigBee Gateway have some ports open including a SSH on port 2333 no luck on the password yet.
PORT STATE SERVICE
2333/tcp open snapp
6668/tcp open irc
12130/tcp open unknown
Hi.
I bought a simple plug and it works fine with z2m. It is detected as tuya plug.
Any thoughts on how to connect Silvercrest Gateway on home assistant ??
I have tested but cannot use It If not with the Lidl Home app
 I really want to integrate this in HA.
Help!
The power strip with z2m only detect one plug
 I hope we get full compatibility with a update.
Yes I confirm the door/windows sensor isn’t’ discovered by the deconz also.
Can you please share the way that you use in order to add this sensor please?
Thank you
Managed to pair the 3 way SilverCrest Smart USB Extension [TY-HG06338-DK (Tuya TS011F)], but zigbee2mqtt only identifies device for the first socket. I can’t seem to automaticly discover the other two sockets. Also, it seems that the 4xUSB will are not controllable (https://youtu.be/R1cLFzcDQNU). Main infor from here. I will continue to explorer this.
See above , I already wrote how I discovered using a conbee II and ZHA. I used the same procedure for all lidl devices I bought : Bulb, led strip, door sensor, PIR and power plug.
I only had problems with the PIR (Motion Sensor) where It sometimes need to be paired several time before it works. Strange.
Enabling the logger helps a lot.
I didn’t bother with the Lidl Home app. I added the gateway to Smart Life directly. It appears in Home Assistant as I have Tuya integration. However the bulbs do not show up in HA. I bought two E27 bulbs, two GU10 bulbs and one LED strip. None of them appear in HA. In the end I removed all of them from Smart Live and integrated them using the ZHA (Sonoff Zigbee Bridge), it saw all of them and I now have them all working in Home Assistant.
I imagine that you flashed the Sonoff zigbee bridge with tasmoto to do this?
Yes, that is correct.
Thanks for the reply.
I was searching and basically its cheaper to have Sonoff Zigbee Bridge. Will return this and order it and them also flash it with tasmota.
Will return everything
 its better to order a sonoff set. It should be more efficient.
Waiting from aliexpress again :unamused:
Buenos dias , tengo una bombilla comprada en España para probar, y se conecta pero dices desconocida, tengo Home assistant, z2m y cc2531
Como ha hecho para poder usarla?
Gracias, si lo consigo hacer funcionar comprare mas
I was unable to connect the smart plug model (https://www.lidl.pt/pt/p/smart-home/silvercrest-tomada-zigbee/p74162) using zigbee2mqtt. I made this pull request and I’m waiting to approval:
https://github.com/Koenkk/zigbee-herdsman-converters/pull/1784
Meanwhile I was unable to connect with the motion sensor that I bought:
My first time I was able to connect and I got this logs:
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:23:57: Device '0xbc33acfffe618279' joined
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:23:57: Starting interview of '0xbc33acfffe618279'
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:23:57: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_connected","message":{"friendly_name":"0xbc33acfffe618279"}}'
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:23:57: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"interview_started","meta":{"friendly_name":"0xbc33acfffe618279"}}'
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:23:57: Device '0xbc33acfffe618279' announced itself
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:23:57: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_announced","message":"announce","meta":{"friendly_name":"0xbc33acfffe618279"}}'
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:04: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"modelId":"TY0202"}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:05: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:08: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"_TZ1800_fcdjzz3s"}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:08: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:11: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"powerSource":3}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:11: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:12: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"powerSource":3}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:12: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:25: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"zclVersion":1}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:34: Device '0xbc33acfffe618279' announced itself
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:24:34: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_announced","message":"announce","meta":{"friendly_name":"0xbc33acfffe618279"}}'
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:39: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"appVersion":65}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:39: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:42: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"stackVersion":2}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:42: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:45: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"hwVersion":1}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:45: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:48: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{"dateCode":"2019.12.12"}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:48: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:51: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'genBasic', data '{}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:51: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:54: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'ssIasZone', data '{"iasCieAddr":"0x0000000000000000","zoneState":0}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:24:54: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:00: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'ssIasZone', data '{"iasCieAddr":"0x00124b00194a1a7c","zoneState":0}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:00: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:02: Received Zigbee message from '0xbc33acfffe618279', type 'attributeReport', cluster 'genPowerCfg', data '{"batteryPercentageRemaining":200}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:02: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:05: Received Zigbee message from '0xbc33acfffe618279', type 'attributeReport', cluster 'genPowerCfg', data '{"batteryPercentageRemaining":200}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:05: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:08: Received Zigbee message from '0xbc33acfffe618279', type 'attributeReport', cluster 'genPowerCfg', data '{"batteryPercentageRemaining":200}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:08: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:14: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'ssIasZone', data '{"iasCieAddr":"0x00124b00194a1a7c","zoneState":0}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:14: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:28: Received Zigbee message from '0xbc33acfffe618279', type 'readResponse', cluster 'ssIasZone', data '{"iasCieAddr":"0x00124b00194a1a7c","zoneState":1}' from endpoint 1 with groupID 0
zigbee2mqtt          | Zigbee2MQTT:debug 2020-11-19 16:25:28: Skipping message, definition is undefined and still interviewing
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:25:28: Successfully interviewed '0xbc33acfffe618279', device has successfully been paired
zigbee2mqtt          | Zigbee2MQTT:warn  2020-11-19 16:25:28: Device '0xbc33acfffe618279' with Zigbee model 'TY0202' is NOT supported, please follow https://www.zigbee2mqtt.io/how_tos/how_to_support_new_devices.html
zigbee2mqtt          | Zigbee2MQTT:info  2020-11-19 16:25:28: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","mesage":"interview_successful","meta":{"friendly_name":"0xbc33acfffe618279","supported":false}}'
After that I reset the device and the device no longer is able to reset to the my zigbee network :frowning:
I tried to change the content inside the database.db and configuration.yaml and I also have no luck
If anyone can help I would appreciate :slight_smile:
Anyone knows if IKEA TRÅDFRI gateway works with Lidl products because Lidl gateway doesn’t work with ZHA integration?
I bought a smart plug model and it works fine. Is detected as “tuya” but it works fine with z2m 1.16.1
In my case I will also keep the SilverCrest gateway because I have 3 radiator thermostatic heads and the Sonoff Zigbee Bridge detects them but I don’t see any entities for them once detected. The rest of the devices I will integrate via the Sonoff zigbee bridge.
You’re right , I update the zigbee version and automatically recognize the smart plug device as Tuya
I just bought the Lidls Smarthome products: led strip, gu10 color, smart plug
 all working with Philips Hue gateway but I can’t make the Extension cable with USB works on Philips. Do you guys know how to do it?
I’m new here! : )
Hello guys ,
I was able to add the motion sensor in zigbee2mqtt:
Has anyone was able to test the sound alarm?
Best regards,
Paulo
Can you also help adding it to ZHA?
