I got some switchable outlets and an outlet strip from Silvercrest. They work quite well, but have annoying LED indicator lights.
In Home Assistant, I can set them to always be off, but the setting has no effect. (Similarily, I can set the default state of the outlet, when it gets plugged in, which also doesn’t work).
Does somebody know a workaround here? Otherwise, I’m just going to hide the LEDs with some tape.
I just checked: I have the plug i mentioned and with Z2M the entity select.xxx_backlight_mode, xxx being the plug, the backlight of the button can be turned off. The change is persistent.
Oh and I didn’t know that this existed, so thank you. Even though it might not help you …
