Simon 100 iO Universe Thermostat
Relative new to Home Assistant so please bear with me.
I have installed components from Simon 100 iO in my appartment. That is dimmers and universe thermostats. The dimmers are working flawlessly, and I’m able to turn on/off, change the luminosity and get a reading of the wattage used.
The thermostats on the other hand…
I have four of these.
zwave.simon_unknown_type_000b_id_0000
zwave.simon_unknown_type_000b_id_0010
Yes, three of the units have the same ID. My dimmers all have different ID. Not sure if that matters though.
Thermostat with ID 0010 and one of the thermostats with ID 0000 have the following entities:
climate.simon_unknown_type_000b_id_0000/0010_mode
sensor.simon_unknown_type_000b_id_0000/0010_relative_humidity
sensor.simon_unknown_type_000b_id_0000/0010_temperature
The two other thermostats with ID 0000 only have the two sensor entities and not the climate entity.
I have checked the zwcfg file and all nodes have the same entities, even though they do not show up in HA.
The two thermostats that have all three enteties I have wokring relative humidity sensor that updates in real time, and I can power on/off, enter away mode, econ mode and heat mode.
What does not work is the temperature sensor. It shows a value but not the same as displayed on the thermostats.
Moving the temperatur bar does not do anything and nothing is even logged in the ozw-log.
If anyone have experience with these Simon 100 iO units and got them to work I would be grateful for any help. All help for that matter… :slight_smile:
Best regards Jon
A tiny update.
All thermostats are now visible in HA but I still have issues with getting the current temperature updated, and set a temperature.
I do see this in the log…
2020-04-05 11:38:21.929 Detail, Node014, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-04-05 11:38:21.930 Detail, Node014, Queuing (Poll) SensorMultilevelCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x31, 0x04, 0x01, 0x25, 0x7e, 0x84
2020-04-05 11:38:21.930 Detail, Node014, Queuing (Poll) SensorMultilevelCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x31, 0x04, 0x05, 0x25, 0x7f, 0x81
2020-04-05 11:38:21.930 Info, Node014, Sending (Poll) message (Callback ID=0x7e, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x31, 0x04, 0x01, 0x25, 0x7e, 0x84
2020-04-05 11:38:21.937 Detail, Node014,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 11:38:21.937 Detail, Node014,   ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 11:38:21.953 Detail, Node014,   Received: 0x01, 0x07, 0x00, 0x13, 0x7e, 0x00, 0x00, 0x03, 0x96
2020-04-05 11:38:21.953 Detail, Node014,   ZW_SEND_DATA Request with callback ID 0x7e received (expected 0x7e)
2020-04-05 11:38:21.953 Info, Node014, Request RTT 23 Average Request RTT 23
2020-04-05 11:38:21.953 Detail,   Expected callbackId was received
2020-04-05 11:38:31.931 Error, Node014, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-05 11:38:31.931 Detail, Node014, Removing current message
2020-04-05 11:38:31.931 Detail, Node014, Notification: Notification - TimeOut
2020-04-05 11:38:31.931 Info, Node014, Sending (Poll) message (Callback ID=0x7f, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x31, 0x04, 0x05, 0x25, 0x7f, 0x81
2020-04-05 11:38:31.939 Detail, Node014,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 11:38:31.939 Detail, Node014,   ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 11:38:31.955 Detail, Node014,   Received: 0x01, 0x07, 0x00, 0x13, 0x7f, 0x00, 0x00, 0x02, 0x96
2020-04-05 11:38:31.955 Detail, Node014,   ZW_SEND_DATA Request with callback ID 0x7f received (expected 0x7f)
2020-04-05 11:38:31.955 Info, Node014, Request RTT 23 Average Request RTT 23
2020-04-05 11:38:31.955 Detail,   Expected callbackId was received
2020-04-05 11:38:41.933 Error, Node014, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-05 11:38:41.933 Detail, Node014, Removing current message
2020-04-05 11:38:41.933 Detail, Node014, Notification: Notification - TimeOut
2020-04-05 12:29:18.013 Error, Node014, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-05 12:29:18.013 Detail, Node014, Removing current message
2020-04-05 12:29:18.013 Detail, Node014, Notification: Notification - TimeOut
2020-04-05 12:30:18.016 Detail, Node014, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
        37
2020-04-05 12:30:18.016 Detail, Node014, Queuing (Poll) SensorMultilevelCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x31, 0x04, 0x01, 0x25, 0x85, 0x7f
2020-04-05 12:30:18.016 Detail, Node014, Queuing (Poll) SensorMultilevelCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x31, 0x04, 0x05, 0x25, 0x86, 0x78
2020-04-05 12:30:18.017 Detail,
2020-04-05 12:30:18.017 Info, Node014, Sending (Poll) message (Callback ID=0x85, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x31, 0x04, 0x01, 0x25, 0x85, 0x7f
2020-04-05 12:30:18.024 Detail, Node014,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 12:30:18.024 Detail, Node014,   ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 12:30:18.040 Detail, Node014,   Received: 0x01, 0x07, 0x00, 0x13, 0x85, 0x00, 0x00, 0x02, 0x6c
2020-04-05 12:30:18.040 Detail, Node014,   ZW_SEND_DATA Request with callback ID 0x85 received (expected 0x85)
2020-04-05 12:30:18.040 Info, Node014, Request RTT 23 Average Request RTT 23
2020-04-05 12:30:18.040 Detail,   Expected callbackId was received
but once every blue moon I see this
2020-04-05 11:39:11.660 Detail, Node014,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0e, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0xe5, 0x0d
2020-04-05 11:39:11.660 Info, Node014, Received SensorMultiLevel report from node 14, instance 1, Temperature: value=22.9C
2020-04-05 11:39:11.660 Detail, Node014, Refreshed Value: old value=23.5, new value=22.9, type=decimal
2020-04-05 11:39:11.660 Detail, Node014, Changes to this value are not verified
2020-04-05 11:39:11.660 Detail, Node014, Notification: ValueChanged
I assume that the default settings for this unit in zwcfg is not correct for this unit.
Am I on the right track here?
Still working on this one… :slight_smile:
I’m told by the distributor of these units needs to be configured to send temperature at defined intervals.
This is what I’m told
Parametre 31, length 1, value 2 (will report based on time set in parametre 32)
Parametre 33, length 1, value 10-1000 (time in seconds between each report)
This is also written in the user manual I have attached below.
I assume that this has to be edited in zwcfg but I have no idea why and how.
	<Node id="13" name="" location="" basic="4" generic="8" specific="6" roletype="5" devicetype="4608" nodetype="0" type="General Thermostat V2" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
		<Manufacturer id="267" name="Simon">
			<Product type="b" id="0" name="Unknown: type=000b, id=0000" />
		</Manufacturer>
		<CommandClasses>
			<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="64">
				<Instance index="1" />
			</CommandClass>
			<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="5" innif="true">
				<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="25.1" />
				<Value type="decimal" genre="user" instance="1" index="5" label="Relative Humidity" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="27" />
			</CommandClass>
			<CommandClass id="64" name="COMMAND_CLASS_THERMOSTAT_MODE" version="2" innif="true">
				<Value type="list" genre="user" instance="1" index="0" label="Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
					<Item label="Off" value="0" />
					<Item label="Heat" value="1" />
					<Item label="Heat Econ" value="11" />
					<Item label="Away" value="13" />
				</Value>
				<SupportedModes>
					<Mode index="0" label="Off" />
					<Mode index="1" label="Heat" />
					<Mode index="11" label="Heat Econ" />
					<Mode index="13" label="Away" />
				</SupportedModes>
			</CommandClass>
			<CommandClass id="66" name="COMMAND_CLASS_THERMOSTAT_OPERATING_STATE" version="1" request_flags="4" innif="true">
				<Value type="string" genre="user" instance="1" index="0" label="Operating State" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="Idle" />
			</CommandClass>
			<CommandClass id="67" name="COMMAND_CLASS_THERMOSTAT_SETPOINT" version="2" request_flags="2" innif="true" base="1" typeInterpretation="B">
				<Value type="decimal" genre="user" instance="1" index="2" label="Cooling 1" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
				<Value type="decimal" genre="user" instance="1" index="8" label="Dry Air" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
				<Value type="decimal" genre="user" instance="1" index="10" label="Auto Changeover" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
			</CommandClass>
			<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="4" innif="true">
				<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
				<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="4608" />
				<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="4608" />
			</CommandClass>
			<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Normal" value="0" />
					<Item label="-1dB" value="1" />
					<Item label="-2dB" value="2" />
					<Item label="-3dB" value="3" />
					<Item label="-4dB" value="4" />
					<Item label="-5dB" value="5" />
					<Item label="-6dB" value="6" />
					<Item label="-7dB" value="7" />
					<Item label="-8dB" value="8" />
					<Item label="-9dB" value="9" />
				</Value>
				<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
				</Value>
				<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Failed" value="0" />
					<Item label="Success" value="1" />
					<Item label="In Progress" value="2" />
				</Value>
				<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
			</CommandClass>
			<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
				<Associations num_groups="1">
					<Group index="1" max_associations="1" label="Group 1" auto="true">
						<Node id="1" />
					</Group>
				</Associations>
			</CommandClass>
			<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
				<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
				<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.61" />
				<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.09" />
			</CommandClass>
			<CommandClass id="139" name="COMMAND_CLASS_TIME_PARAMETERS" version="1" request_flags="4" innif="true">
				<Value type="string" genre="system" instance="1" index="0" label="Date" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="07/04/0101" />
				<Value type="string" genre="system" instance="1" index="1" label="Time" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="17:18:41" />
				<Value type="button" genre="system" instance="1" index="2" label="Set Date/Time" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="button" genre="system" instance="1" index="3" label="Refresh Date/Time" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
			</CommandClass>
		</CommandClasses>
	</Node>
Am I still on the right track?
Best regards
I have added this;
				<Value genre="config" index="31" label="Temp" max="3" min="0" size="1" type="byte" value="2">
                <Value genre="config" index="33" label="Time" max="1000" min="3" size="1" type="byte" value="30">
			</CommandClass>
to each node. What happened when I started HA again was that all climate.simon_unknown_type_000b_id_0000/0010_mode entities were lost. Rebooting, thus loosing the config I manually added, got one climate entities back. I have edited the zwcfg again and I’m hoping that the climate entities are coming back.
Me again…
Got it to work.
Added
<Value genre="config" index="31" instance="1" label="Automatic reports" max="3" min="0" size="1" type="byte" value="2">
</Value>
<Value genre="config" index="33" instance="1" label="Time difference" max="1000" min="10" type="short" value="10">
</Value>
to <CommandClass id="112"...>.
Now if I only can get COMMAND_CLASS_THERMOSTAT_SETPOINT to work...
I also got setpoint to work… more or less.
  <Value genre="user" index="1" instance="1" label="Heating" max="37" min="5" read_only="false" type="decimal" units="C" value="20" write_only="false"/>
  <Value genre="user" index="3" instance="1" label="Cooling" max="37" min="5" read_only="false" type="decimal" units="C" value="21" write_only="false"/>
  <Value genre="user" index="11" instance="1" label="Energy Heat" max="37" min="5" read_only="false" type="decimal" units="C" value="16" write_only="false"/>
</CommandClass>
Index 1 sets temperature in “manual mode”. Index 11 sets temperature i “auto mode”.
I’m missing the index for “away/vacation mode”. How do I go about finding that? Trial by error?
Dear Exxon,
I have installed simon 100 io pro hub with some dimmers for lights and motorized shutters.
If I´m not wrong, you have them integrated in home assistant. I´m just trying it.
Will I need a z-wave hub? Which one are you using?
Thanks in advance.
Hi @exxon,
Can you explain how do you installed the Simon IO in Home Assistant? Can you recommend the way to go?
@saliendodelaratrace
any news about it
Also interested on this, I am planing to start to integrate Simon IOs on Home Assistant, but i do not see any documentation or info about anyone doing this…
Anyone can explain how they did it?
Thanks in advance
Hi again,
Just if it helps someone.
I have a few simon 100 io integrated in home assistant as follow:
1.- Get a z-wave hub (aeotec z-stick gen 5)
2.- In home assistant go to addons and install z-wave JS
3.- Go to settings / devices and services / add integration / add a z-wave device
4.- Click center button of the simon io device 2s<t<10s and release
5.- If everything went well, the you can see now the new device
The only problem I have is with some master io shutter that doesn´t get any configuration from the database or wherever.
Thanks, i will try on some days/weeks (i have to buy the hub and ensure I have some hours to play) and will keep you posted.
thansk
Hi
I finally get the Z-Wave hub and properly added to home assistant with no issues.
But I can not add any device.
I tried with different seetings (secure, insecure…), I disconnec from my hub and tryed…
I confirm this device can be added again to my simin hub, so discover is working…
Do I need to do anything special or configure on anyway?
can devices added manually somehow?
thansk
I finally was able to add, basically it was a problem removing device from vendor App, i was able to delete, but it was still associated behind the scenes.
thansk
Completely new here. Have installed Simon 100 iO in the whole house. Have you had any success with adding master switch or dimmers. I do not get them to work. If I succeed adding them (which is happening a bit randomly) they appear as connected but I do not get them to associate with other Simon 100 Io slaves and they do not perform any operation. Any advice
