I want to replace some mechanical Honeywell xe70 series t6371 which i’m using for HVAC system with something smart allowing me to lock temperature and schedule on/off time.
It would be amazing if configurable via Home Assistant (via mqtt ?) as i already use shellies devices to mange some of my building automations (boilers, pumps and temperature).
I also have some Aermec WMT10 Aermec PXA I and it would be amazing if i can work on them too. I think that the only problematic step is that these are not actively powered by 220v. I’m in Italy.
Yeah as multiple shelly won’t be cheap as i have several of these thermostat.
As they are “stupid” fancoils i think i can just turn the power off on temperature so i just need a single shelly and leave the thermostat mounted to control the rest of the functions.
I bought directly from them paying via PayPal.
The device arrived without issues. I bought one piece spare as the warranty management from china may be problematic…
Great post sales support, they fixed an issue I found via OTA upgrade after only 2 days
Still haven’t found a cheap and scalable solution for these thermostats.
An ESP would require a power adapter which is no really a easy setup for a wall mounted thermostat.
Do you think it enough to place a shelly here and use it as a normal switch?
Then i will probably also need an addon for the temeprature sensor. And i don’t know if i have enough room for all of that. I could use a shelly blu H&T to avoid space problems where the cables are but it would add the battery hassle.
I’m also investigating a possible alternative for some rooms where i don’t have a wifi connection.
To partially address this (in some rooms where i can) i’m now controlling via a virtual thermostat the water pumps so they stop once the desired temperature is reached.
I’m controlling them via bacnet/IP as they are on an eagle honeywell controller (which i cannot expand or edit as it requires an expensive licence).
