When motion sensor one and two don’t show motion for two minutes I want it to turn off the light, this is what i have now but don’t understand why its not working?
- alias: Turn off Garage light
platform: state
condition:
condition: and
conditions:
- condition: state
entity_id: binary_sensor.inside_motion_1
state: off
for: 00:02:00
- condition: state
entity_id: binary_sensor.inside_motion_2
state: off
for: 00:02:00
service: homeassistant.turn_off
entity_id: switch.g_inlight
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/automations.yaml”, line 466, column 3
expected , but found ‘’
in “/config/automations.yaml”, line 469, column 4
do yall see some where the spacing is off?
platform: state
condition:
condition: and
conditions:
- condition: off
state: off
for: 00:02:00
- condition: off
state: off
for: 00:02:00
You’ve defined nothing to trigger the automation. How were you planning to execute it? If you use platform: state then you also need to supply an entity_id.
The second version you posted is invalid. There’s no such thing as condition: off.
I find NodeRed extremely unintuitive, confusing, and unnecessarily complex. I prefer to use the built in YAML automation engine or AppDaemon for more complex tasks.
Maybe you don’t find writing python or yaml as easy as others, but NodeRed certainly isn’t for everyone either.
As 123 pointed out, you didn’t properly define a condition.
Automations have to be triggered, meet a set of conditions, then do an action.
Sometimes that condition can be blank and on every trigger it does the action, but it needs a trigger to do the action no matter what.
- id: turn_off_garage_light
- platform: state
to: 'off'
for: '00:02:00'
- platform: state
to: 'off'
for: '00:02:00'
condition:
condition: and
conditions:
- condition: state
state: 'off'
- condition: state
state: 'off'
- service: homeassistant.turn_off
The above code, adapted from what you had before, will trigger when either sensor if off for two minutes, only continue if both are off, then do your action.
The shortfall of this is that if one sensor is off for 2 minutes and other other is off for 10 seconds, the action will still occur. If that acceptable? Or you you truly need both off for 2 minutes before turning off the light?
Sorry for late response: So with node red you have have to make you have to make state nodes for each of your motion sensors. They will turn on and off automatically when the state changes. Link to states to a set function for example: set.flow(“senosr1”, “on”). Now you can call those function within any process just by copy pasting nodes. For instance if you want your sensor 2 to open the garage door as well you don’t need to write the whole thing from scratch all you do you drop the get function between the two nodes. Node red is easier to implement because you can reuse a function just by copy/paste and drag drop. Hope it helps.
yeah both would need to be at least 2 mins, because I may be in another part of the garage and the lights may go out. Something like (if sensor 1 & sensor 2 = “off” for 2 mins then turn off lights)
What is the purpose of the OR condition in your example?
The automation can only be triggered by either of the two motion sensors remaining off for at least 2 minutes. The condition checks if either of the two motion sensors is off for at least 2 minutes. Seems like a redundant check.
EDIT
This is functionally equivalent to the automation you posted:
- platform: state
entity_id:
- binary_sensor.inside_motion_1
- binary_sensor.inside_motion_2
to: 'off'
for: '00:02:00'
If either of the two motion sensors is off for at least 2 minutes, then the switch is turned off. If that’s not the behavior you want then the example you posted is incorrect.
If you want to turn off the switch only if both motion sensors have been off for at least 2 minutes, convert your example’s condition from or to and.
Your first automation from 2 years ago, was actually almost, what you wanted, except:
It was missing the trigger, which was suggested in the following posts. You put more ore less the same logic in trigger and condition. The difference is that “trigger:” is combine by “OR”, whereas condition is combined by “AND”. So there is no need for your explicit “AND” in your initial conditions.
You need both, because the automation should trigger (and evaluate the condition) whenever either one of the sensors is off for 2 min, but the action should only execute when both sensors are off for 2 min. You could even leave out the time-constraint in the trigger. It just determines how often the condition is evaluated.
The indentation of “condition:” is incorrect. It should be the same level as “trigger:”. In your latest configuration the “to:” and “for:” are also indented wrong.
Not really. Here’s the thing when using “Check Congifuration” it might run and report ‘configuration valid’ but that might not actually be the full story. It may have more to say and it will state it with a Persistent Notification informing you that something is indeed wrong and you should check the Log for more details.
Case in point is the code you posted. Anyone who has seen an automation or two knows that its trigger is dead wrong. Running `Check Configuration’ produces the following persistent notification and error message in the Log:
Logger: homeassistant.config
Source: config.py:445
First occurred: 1:00:00 PM (1 occurrences)
Last logged: 1:00:00 PM
Invalid config for [automation]: extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘to’]. Got None required key not provided @ data[‘condition’][0][‘conditions’][0][‘state’]. Got None required key not provided @ data[‘trigger’][0][‘platform’]. Got None. (See ?, line ?).
So, no, it didn’t truly pass config check despite the ‘configuration valid’ message you saw. Chalk it up to one of Home Assistant’s quirks.
