Simple Annunciator Panel - The Wife Approved GUI
I posted this under a different topic before, but this has been so incredibly useful for me that I think it deserves an update. This is the #1 UI element of my Smarthome system. It is simple, self-explanatory, and has the seal of officially being wife approved. Let’s cut to the chase:
Let’s take a look at the GUI code, which is a simple glance card that leverages tap_action and the custom script (included after the UI) script.sensor_target_toggle. For each annunciator item you want to control, you specify the entity id of that item as the target. In order to show an item as on/off in the UI, you also need to specify a sensor, by providing the entity id of the object which represents the on/off state of the annunciator item. More often than not, this will be the same entity id as the control item. Huh? Isn’t that obvious? If you want to see the state of the Kitchen Ceiling Fan, of course you should look at its state. But there are cases where you may have several different lights, which taken together make up a scene. Suppose you have lights A,B,C which make up switch.my_scene, and you consider the scene to be on/off if light B is on/off. To control this with the annunciator, the target_id would be set to switch.my_scene, and the sensor_id to be light.B.
Lovelace YAML (be sure to visit material design for lots of great icons!)
type: glance
title: My Annunciator
columns: 4
entities:
  - entity: binary_sensor.family_room_main
    icon: 'mdi:sofa'
    tap_action:
      action: call-service
      service: script.sensor_target_toggle
      service_data:
        sensor_id: binary_sensor.family_room_main
        target_id: switch.family_room_main
  - entity: binary_sensor.kitchen_main
    icon: 'mdi:silverware-fork-knife'
    tap_action:
      service_data:
        sensor_id: binary_sensor.kitchen_main
        target_id: switch.kitchen_main
  - entity: binary_sensor.movie
    icon: 'mdi:movie-open'
    tap_action:
      service_data:
        sensor_id: binary_sensor.movie
        target_id: switch.movie
  - entity: switch.2frb1_fr_fan
    icon: 'mdi:fan'
    tap_action:
      service_data:
        sensor_id: switch.2frb1_fr_fan
        target_id: switch.2frb1_fr_fan
  - entity: binary_sensor.stairs_all
    icon: 'mdi:stairs'
    tap_action:
      service_data:
        sensor_id: binary_sensor.stairs_all
        target_id: switch.stairs_all
  - entity: binary_sensor.upstairs
    icon: 'mdi:lamp'
    tap_action:
      service_data:
        sensor_id: binary_sensor.upstairs
        target_id: switch.upstairs
  - entity: binary_sensor.dimmer
    tap_action:
      service_data:
        sensor_id: binary_sensor.dimmer
        target_id: switch.dimmer
  - entity: light.1sta1_porch_light
    icon: 'mdi:coach-lamp'
    tap_action:
      service: light.toggle
      service_data:
        entity_id: light.1sta1_porch_light
  - entity: light.2frb3_deck
    tap_action:
      service_data:
        entity_id: light.2frb3_deck
  - entity: light.39351_zw3005_in_wall_smart_dimmer_level
    tap_action:
      service_data:
        entity_id: light.attic_fan
  - entity: binary_sensor.nightlight
    tap_action:
      service_data:
        sensor_id: binary_sensor.nightlight
        target_id: switch.nightlight
  - entity: switch.mbr_reading
    tap_action:
      service_data:
        sensor_id: switch.mbr_reading
        target_id: switch.mbr_reading
  - entity: switch.mbr_master_bedroom_general
    tap_action:
      service_data:
        sensor_id: switch.mbr_master_bedroom_general
        target_id: switch.mbr_master_bedroom_general
  - entity: switch.mba_bathroom
    tap_action:
      service_data:
        sensor_id: switch.mba_bathroom
        target_id: switch.mba_bathroom
  - entity: switch.shower
    tap_action:
      service_data:
        sensor_id: switch.shower
        target_id: switch.shower
  - entity: switch.hs_ws100_wall_switch_switch
    icon: 'mdi:fan'
    tap_action:
      service_data:
        sensor_id: switch.hs_ws100_wall_switch_switch
        target_id: switch.hs_ws100_wall_switch_switch
and the code for the script:
sensor_target_toggle:
  alias: 'Sensor Target toggle'
  description: 'Get the sensor state and toggle the target'
  fields:
    sensor_id:
      description: 'Sensor entity_id'
      example: binary_sensor.porch_deck
    target_id:
      description: 'Target entity_id'
      example: switch.porch_deck
  sequence:
    - service_template: >
        {% if is_state(sensor_id, 'on') %}
          switch.turn_off
        {% else %}
          switch.turn_on
        {% endif %}
      data_template:
        entity_id: >
          {% set entity = target_id %}
          {{entity}}
You can also create your own binary sensors if you want a more elaborate “scene sensor”. The example below is a binary sensor that determines if the “Family Room Main” scene is on if the brightness of light.fr_spotlight is between 50% and 60%.
    family_room_main:
      value_template: >-
        {% set pct = ((states.light.fr_spotlight.attributes.brightness | float / 255) | abs )%}
        {% set ret = (0.5 <= pct) and (pct <= 0.6) %}
        {{ ret }}
