I have a Woox bulb that I have integrated to HA Green via the Tuya integration.
The bulb is working just fine just outside my front door. I have a simple button on my Home dashboard that corretly turns the bulb on/off and can adjust the brightness.
So the integration is seemingly working fine.
I wanted to create an automation for the bulb to turn on automatically as it starts to get dark outside in the evenings.
for several days now, the automation has triggered as expected and run without error, yet the bulb is not on.
I am at a loss for how to figure out why the light does not turn on because everything I’ve looked at in HA so far shows that everything worked as HA expected.
Here is my automation YAML (though I have used the GUI to build it):
description: ""
# Trigger when the sun is low
- platform: numeric_state
entity_id:
- sun.sun
attribute: elevation
below: 2
condition:
# Make sure the trigger is due to the sun being low in the evening rather than morning
- condition: time
after: "14:00:00"
# Make sure the light doesn't keep trying to turn on through the night (I want another automation to turn it off at 23:00)
- condition: time
before: "23:00:00"
# Turn the light on
- service: light.turn_on
metadata: {}
data: {}
device_id: 5739ba4372a4bc7ec14e6cd928100ca6
mode: single
Trace timeline from the last trigger (yesterday evening) is:
Traces logs from the same run are
The two conditions are shown to be evaluated with result: true
The action step Traces Step Details are:
Executed: 4 August 2024 at 20:54:52
Result:
params:
domain: light
service: turn_on
service_data: {}
device_id:
- 5739ba4372a4bc7ec14e6cd928100ca6
running_script: false
Step Config looks like:
metadata: {}
data: {}
Changed variables looks like:
context:
parent_id: 01J4FFB0X048B23G2YRA81RKWD
user_id: null
As a test this evening I have disabled the “Light” Action, and instead added a “Device” Action that should do the same thing .
Can anyone see any rookie mistake(s) that I have made?
